Old 12-12-2006, 01:49 PM   #1 (permalink)
Date registered: Jan 2005
Send a message via AIM to sergiuvlad Send a message via MSN to sergiuvlad Send a message via Yahoo to sergiuvlad
Help - possible blown gasket
Folks
I am an ex-W211 owner and my cousin recently got a W210 (1997 E320). He just noticed large oil stains under the car and, upon further inspection, saw 3 places where the engine compartment leaks oil (even when the car is off) and seems to be splattering all over the place when on. He is on his way to the dealer but I have a few questions for people who might know more about cars than us:
- if it's a blown gasket is it worth trying to fix it with one of those sealants you add to your oil (available at AutoZone)? Or are those for lower end cars and can futher damage his? In any case, would you recommend anything along these lines?
- how much should an engine gasket replacement cost?
- how long can he drive like that and what more can happen (if he doesn't make it to the dealer in time)? I mean, can the engine go altogether?
- finally, he had an oil change at a Shell station, if is it possible this was caused by using the wrong oil, oil that's not synthetic etc?
Any help/feedback is highly appreciated
Thanks a lot,
Sergiu
sergiuvlad is offline   Reply With Quote
Old 12-12-2006, 02:36 PM   #2 (permalink)
Vehicle: ML500, E320 4Matic
Premature to say what it will cost as you do not know whay is leaking. As for engine damage, if he runs out of oil, for sure, if he does not most likely not depending on what it is. Cause, could be the oil change if it started right after but not because of the type of oil. Drain plug, filter would be the first places I would look. Do not try to fix with addatives, that could cause damage and most of them don't work anyway in any type of car. Have it looked at right away. Going to the dealer is a good idea, Shell Station was a bad idea
sosh is offline   Reply With Quote
Old 12-12-2006, 03:25 PM   #3 (permalink)
Date registered: May 2004
Vehicle: 97 E320 130k miles
New head gasket will cost you around $2500 to replace. If the car still has the original wire harness, it will probably break during the HG removal due to the insulation being brittle over time. This will add another $1,000 to the cost. Budget around $3500 for the whole thing and if the wire harness is OK, maybe $1000 less.
I know as I'm going through the same estimate process currently.
smazur is offline   Reply With Quote
Old 12-12-2006, 04:02 PM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Originally Posted by sergiuvlad
Folks
Thanks a lot,
Sergiu
JOE55 is offline   Reply With Quote
Old 12-12-2006, 05:51 PM   #5 (permalink)
Read the post. The guy said it was an oil leak, a head gasket will not leak much oil, just coolant.
Old 12-13-2006, 10:09 AM   #6 (permalink)
Yeah, it was leaking oil not coolant. Let's see what the dealer says (took it there this morning). Damn, $3500 is like half the value of the car....
And I agree, the Shell station was a moronic idea, I told him not to...
Old 12-13-2006, 09:39 PM   #7 (permalink)
Alright, the dealer confirms it's a blown gasket and estimated $2400 in repairs (parts and labor). Granted that the diagnostic fee is not refundable (not sure how much it is at this point), is this a reasonable price or should he shop around a little more?
Head gasket blown? gregdeklerk W201 190E, D-Class 5 09-29-2006 04:04 PM
79 300 D blown head gasket fix? vstech W123 E,CE,D,CD,TD,TE Class 2 03-24-2006 05:22 PM
blown exhaust manifold gasket 3199cc W208 CLK Class 1 10-06-2004 08:20 PM
BLOWN HEAD GASKET Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 01-28-2002 11:11 AM
Blown Head gasket on 280GE E T Bass G-Class 3 11-05-2001 02:53 PM
