Old 12-12-2006, 06:16 AM   #1 (permalink)
Date registered: Jan 2005
door sill question
The metal plate used on the rear door sill (probably on front doors too) came loose and in investigating I found that two of the three, small, plastic fasterners that are like pop-rivets had broken. These fit into a slide on the bottom of the metal plate and then pop into the hole in the lower door opening which then locks the plate into place.
I've never seen this same type of plastic fastener but I'm sure if I went to the dealer they would sell me some. But, my kids were really counting on me getting them something for Christmas this year and I don't think I can afford to do both. (of course I'm being a little facetious here) So, does anyone know where these can be found online? I'm thinking that would probably be the least expensive source.
Thanks for any help.
silver00E320 is offline   Reply With Quote
Old 12-12-2006, 10:28 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
ebay...
JOE55 is offline   Reply With Quote
Old 12-12-2006, 03:25 PM   #3 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
The "plate" is plastic, and failure is common.
So common, it appears, my dealer had them in stock in my color.
They're only $25-35 IIRC.
Kent Christensen
Albuquerque
Old 12-13-2006, 02:43 PM   #4 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Is the sill plate broken?
Greets,
If the sill "plate" (plastic) is not broken, and the "slot" rail underneath is intact, then all you need are new "male" plastic fasteners. You just slide them down the rail slot, and plug into the female portions in the door frame.
As I recall, I paid 50 cents each for the 3. Hopefully this will save you enough that you can still be "Santa!"
Here's the EPC as an attachment.
It is part number "77"
MB# A0019887681
Granted, this if for my '98 E320, but should be the same.
Good luck, and let me know.
G-AMG is offline   Reply With Quote
need door sill HELP!!! simon_dawson W203 C-Class 16 03-10-2004 09:56 PM
ML 55 AMG Door Sill Question... pauls W163 M-Class 4 12-27-2002 10:15 AM
door sill.............. ed W163 M-Class 7 11-11-2002 12:04 PM
Door Sill Guest (MBNZ) W203 C-Class 0 02-22-2002 09:37 AM
Question for Arnee - lighted door sill installation RobD R170 SLK Class 1 11-29-2001 08:30 PM
