Old 12-10-2006, 03:42 PM   #1 (permalink)
Date registered: Mar 2006
Idle adjustment on 220TD - Help!
The idle on my 2001 E220TD seems to be a little lower than it should.
The engine vibrates and the condition is more annoying than concerning at the moment.
The speedo reads 750 max at cold, but if you touch the accelerator slightly to about 800, again reading from the speedo, the vibration disappears.
Is there a way of adjusting the idle speed or is it the sign of a certain component on its way out?
The car has full MB service history and currently has 125,000 miles on the clock. with the next service due in 2100miles time.
Any assistance much appreciated.
chicomerc is offline   Reply With Quote
idle adjustment. benztece W124 E,CE,D,TD Class 18 04-19-2006 06:14 PM
Idle adjustment of 84 300gd. gwagoncar G-Class 1 03-27-2006 04:53 PM
Idle adjustment on 380se Alex126 General Mercedes-Benz 1 10-22-2005 11:44 PM
Idle adjustment and Thank You!!! izeljic W123 E,CE,D,CD,TD,TE Class 2 06-05-2003 06:09 AM
idle adjustment Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 10 01-25-2003 10:25 AM
