Old 12-09-2006, 11:11 AM   #1 (permalink)
rsmith's Avatar
Date registered: Nov 2006
Vehicle: 1990 560 SEC 1988 560SL 1998 E320 4matic wagon
W S Switch? What does it do?
Hey all, I just bought a 98 E320 4 matic wagon 120Kmi but no books or records. The guy is supposed to send them to me. I hope. I can't figure out what the w/s switch is for next to the shift. Also I looked at the post on oil change the guy says 0w45 mobil 1 is recommended but under what temp conditions?
Drove the car from Pittsburg to Philly ran great 26mpg and used no oil. Can anybody tell me if these have any issues like the timing chains in my 560's that need to be addresed
thanks
rsmith is offline   Reply With Quote
Old 12-09-2006, 11:18 AM   #2 (permalink)
one.bofh's Avatar
Date registered: Jul 2006
Vehicle: 2001 E320
S - standard driving mode
W- winter driving mode (starts from 2nd gear)...
I haven't lost my mind - it's backed up on a tape somewhere.
one.bofh is offline   Reply With Quote
Old 12-09-2006, 01:17 PM   #3 (permalink)
rsmith's Avatar
thanks for the qick reply do you know what the logic is for starting in 2nd gear
Old 12-09-2006, 02:00 PM   #4 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Welcome to the forum, rsmith.
I'm going to guess you've never lived in snow country.
Starting in first gear is when the greatest amount of torque can be applied to the wheels.
Torque is an enemy in poor traction situations.
Starting in second gear lessens the likelihood of wheelspin.
Take care and enjoy the Florida weather!
Greg
Meister Eckhart
Old 12-10-2006, 02:04 PM   #5 (permalink)
one.bofh's Avatar
Vehicle: 2001 E320
Thumbs up
^^^ What gregs210 said... He usually has a way of explaining everything properly...
Old 12-11-2006, 12:28 AM   #6 (permalink)
Date registered: Dec 2003
Vehicle: '99 E-300 DT (W-210)
Talking More . . . .
When the "W" switch position is used, there is also a higher ratio for reverse.
In other words, you have two speeds for reverse.
Don't try to use the higher ratio when backing up hill, as it seemed
to me that my E-300 DT was staining when I tried this.
The trans did not like it, so I stopped doing it, and would always throw
the switch back to the "S" position prior to engaging reverse.
If you change positions of the switch after you are already in reverse, nothing changes.
You must position the W/S switch first prior to placing the lever in "R."
When using this feature in any of the forward positions except 1, you'll be able
to force an early shift from first to second speed by throwing the switch to "W."
Your manual should explain all of this if and when you get it.
Good luck.
E-300 DT is offline   Reply With Quote
CRIKEYS !!!...What's this switch for ?...Mystery Switch blitzgritz W123 E,CE,D,CD,TD,TE Class 7 03-20-2006 12:02 PM
hazard switch/seat switch kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 1 02-04-2006 06:35 PM
And this switch does.................. conleycrew3 W124 E,CE,D,TD Class 7 11-23-2005 09:59 AM
no power to roof switch +roll bar switch ELV R129 SL Class 0 07-03-2005 03:37 AM
I would like to replace my speaker fader switch with a door lock switch but… barbus W123 E,CE,D,CD,TD,TE Class 1 01-25-2005 08:05 AM
