where is horn fuse in W210 1997? :confused: - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 12-07-2006, 08:02 AM Thread Starter
.::Ğї::.'s Avatar
Vehicle: Mercedes Benz E320
Send a message via MSN to .::Ğї::. Send a message via Yahoo to .::Ğї::. Send a message via Skype™ to .::Ğї::.
Exclamation where is horn fuse in W210 1997? :confused:
hello people! my hotn fused burned and i dont know where it is to change it does anyone have map of fuse box on w210 1997 or any king on manual???
thanks a lot!
.::Ğї::. is offline
post #2 of 12 (permalink) Old 12-07-2006, 10:44 AM
Date registered: Nov 2005
Vehicle: 1996 210.020
On my '96, the horn fuse is on the K40 relay module. That is the frontmost part inside the module box, near the cabin air intake.
Matt L is offline
post #3 of 12 (permalink) Old 01-04-2007, 12:37 PM
Date registered: Nov 2006
Hello, my 97 e420 horn just went out too. I search everywhere but coun't find fuse K40 or K41. Did you find the fuse? If not how did you fix yours.
Thanks
jadi is offline
post #4 of 12 (permalink) Old 01-04-2007, 06:57 PM
I don't know of any K41. K40 is inside the module box. That's under the hood at the right rear (just ahead of the climate-control air intake).
Matt L is offline
post #5 of 12 (permalink) Old 01-06-2007, 09:20 AM
You mean the fuse box next to master cylinder under the hood on driver side. The number only went up to 26. I check every fuse, they all good.
jadi is offline
post #6 of 12 (permalink) Old 01-06-2007, 12:34 PM
Right rear. That's the passenger side for those of us in the US. It's a rather large box, with four phillips-head screws holding the cover down.
The fuse isn't number 40. It's on the K40 relay module, along with a few others. Sorry, I don't remember which one protects the horn circuit.
Matt L is offline
post #7 of 12 (permalink) Old 01-06-2007, 09:55 PM
Ok, just got home from work. Will check tomorrow. I did open that box while looking for the fuse. I will now look for the K40 module. I remember there is computer for the car inside among a lot of other connectors and a few (6+/-) 15A fuse and a 40A fuse. Thanks for the info. Will keep you posted.
jadi is offline
post #8 of 12 (permalink) Old 01-06-2007, 10:36 PM
Vehicle: 99 e320 smoked silver
the horn fuse is in the module control box near the cabin intake it the fuse standing in front of the grill looking twoards the rear of the car its the fuse all the way to the left there should only be four in there
hope that helps
mbj898 is offline
post #9 of 12 (permalink) Old 01-08-2007, 08:51 AM
All the fuse in there are fine. Replace one of the horn in the front with a new one I got from Pepboys still not working. Pull it out, hook it up on the other(low). ...Nothing. Any ideas?
jadi is offline
post #10 of 12 (permalink) Old 05-18-2007, 09:04 PM
Vehicle: Mercedes E320
Had a horn fuse blown on my E320 , thanks to this forum after a bit of confusion managed to replace it. Attached image of module with horn fuse(extreme left).They are all 15 amp.Name:  Horn_fuse.jpg
Mzeedz is offline
    Where is the Horn Fuse? jeff338 W210 E-Class 23 07-16-2016 07:17 PM
    Fuse #21 Blows When Car Is Started - 1997 S320 blacksclass W140 S-Class 8 12-13-2015 10:35 PM
    W210 mirror removal?!! very confused LCN W210 E-Class 12 12-14-2006 08:11 PM
    Replaced Fuse -- Need Radio Code C230 (1997) raleighbob Audio & Telematics Forum 0 10-29-2006 09:36 AM
    E420 (W210 chassis) 1997 jiggie General Mercedes-Benz 1 01-29-2006 09:50 PM
