» Site Navigation
» Other Sites
Old 11-26-2006, 08:01 PM   #1 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Photo Diy- Spark Plug Change.
Greetings all.
As promised, I did the plugs today.
It is a bit of a chore, but no real tricks involved. Just lots-o-tight spaces.
You will need a few special tools, including a slim profile spark plug socket.
I used a Stahlwille socket#51, a 16mm socket with rubber insert.
A T27 Torx bit and a Low Range torque wrench (for the Torx screws- 8Nm),
and a regular range torque wrench for the Spark Plugs (28 Nm).
Another tool that made the job easy, was MB part# 110 589 01 01 00, aka
Hazet # 2771. Lucky me, it happens to be the same tool used to adjust the valves on the Old 280GE. Two for the price of one! You can actually find those
floating around on Ebay for cheap. It is worth every penny for this job. You use the wrench to pry the spark wire off the plug.
Other helpful items were 3" and 5" extensions, and a U-Joint.
In all, it took around 3 hours. A preatty straight forward procedure.
Although the coils and plug/block areas ARE marked with A & B, I was paranoid, and just did one plug/plug wire at a time, JUST IN CASE!
PLEASE NOTE!! AFTER RECHECKING THE COMPANY'S WEBSITE, THE SPARK PLUGS **DO NOT NEED!!** ANTI-SEIZE PASTE!!!
G-AMG is offline   Reply With Quote
Old 03-03-2007, 10:09 AM   #2 (permalink)
Date registered: Mar 2007
Spark Plug update RE: Stahlwille Socket " 51 16 mm
G-AMG,
Will I need this reduced socket on my 2000 C280 V6 engine (202)
I am trying to id the proper spark plugs in the owners manual it states
Bosch F8DPER however, after going online I can'r seem to detect this partumber.
Is there a update to this plug with another P/N. Other on line parts sources don't show this P/N. Can anyone advise about which is a better plug Bosch or NGK. If so, can you advise P/Ns for each. Got about 60K and its about time for a change of plugs.
Thanks for feedback.
psenders is offline   Reply With Quote
Old 03-05-2007, 01:21 PM   #3 (permalink)
G-AMG's Avatar
Try EPC
Hi.
Here's an EPC for you. It should have whatever the latest P/N for you.
Old 03-19-2007, 08:50 AM   #4 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
GAMG, what is the MB recommended interval for the spark plugs?
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 03-20-2007, 08:58 AM   #5 (permalink)
G-AMG's Avatar
Spark Plug Change Interval.
According to the Schedule, it is at 100,000 Miles
Old 05-11-2008, 09:02 PM   #6 (permalink)
hilarushi's Avatar
Date registered: Jan 2007
Vehicle: 1998 E320
Post how to remove your spark plugs wires
For E320 V6.
It is difficult to remove the spark plug wires on this V6 engines. This is what I did. You can give it a try. Pull your wire strait out in the direction of the plug.
This might work for you, it worked for me with no problems.
Current:
1998 E320
Old Friends,
2004 Hyundai Tiburon
1997 Benz E420
1996 Lexus ES300
1988 Benz E300
2000 Focus SE
2000 VW Jetta GL
hilarushi is offline   Reply With Quote
Old 05-11-2008, 09:15 PM   #7 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
You
only need to remove the plug wire from the boot end and leave the other end fixed to the coil.You do this the proper mb way with the special 17mm offset tool mentioned above and on sale from me for $28 delivered stateside.Makes the job a snap,pops them off ,helps pop them back on and no damage to the wires.
ngk7090 plugs are oe and the closest match to the oem platins that work so well.They are only $2.75 at most auto stores.No anti seize needed they are plated in a dry metal anti seize.
pm me for shipping info on the boot tool,the transmission dipstick or the boxed set of dash cluster and radio/climate control removal tools.
ohlord
Old 05-11-2008, 09:31 PM   #8 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Exclamation
Hey, folks. I have seen some creative ways to remove these boots from the plugs, but however you do it don't ever pull on the wire itself. Never. Your force should always be exerted on the boot only and as noted in the same plane as the plug angle to the head. This rule/advice is not limited to MB vehicles but all cars; it is just far more critical on these engines because the wires are $15-$25 each depending on if you buy them individually (and where) or as a complete set, and they are easily damaged in part because they fit so tightly.
While hilarushi's solution is creative -- and almost free -- I think the physics involved would impart a partial angle to the pull, which is probably okay but might increase the effort needed. In any case wrapping the wire around each of 12 plug boots is lots more effort than the 17mm offset wrench or the Lisle tool.
Take care and enjoy the ride,
Greg
Old 07-01-2008, 11:09 AM   #9 (permalink)
Date registered: May 2008
Vehicle: 1999 E320
1999 E320 Wagon 93K, Changed my plugs (NGK 7090) last week - first time I had ever changed spark plugs on any vehicle. Took about 3.5 hours but I was taking my time. I didn't run into any major snags - the old plugs were really screwed in tight though. The Spark Plug tool sold by Oh Lord was critical. It really made pulling the boots off a snap and what became quickly apparent was its usefulness getting the boots back on in the confined space. The drivers side plugs look more difficult but they were actually the easiest. My electrodes had worn out to the point that they were all showing a gap of about .45 (vs the recommended .39/.40) but the car had been running fine. I just changed them since the car had so many miles on it and I am getting ready to leave on a cross country trip. This is a great website for DIY maintenance and I will post anything I can that may help out someone in the future.
Brian E is offline   Reply With Quote
Old 07-02-2008, 12:47 PM   #10 (permalink)
squirrelonfire's Avatar
Vehicle: 1998 Mercedes E320
Send a message via AIM to squirrelonfire Send a message via MSN to squirrelonfire Send a message via Yahoo to squirrelonfire
Ok so the spark plugs inside that compartment or something?
squirrelonfire is offline   Reply With Quote
Photo Diy Of Fuel Filter Change G-AMG W210 E-Class 31 08-26-2008 03:37 AM
Photo Diy- Rear Differential Oil Change G-AMG W210 E-Class 30 07-31-2007 09:10 AM
diy spark plug replacement but engine still runs rough busoptr W163 M-Class 8 11-02-2006 08:03 AM
My first spark plug change.. ttaleric W163 M-Class 16 08-23-2005 10:32 PM
SPARK PLUG CHANGE ALBERTO W208 CLK Class 13 10-04-2004 07:35 PM
