Old 11-23-2006, 12:30 PM   #1 (permalink)
Date registered: Sep 2006
Unhappy How to replace a little headlight bulb?
All,
Can somebody show me how to replace the inner headlight bulb?
Happy ThanksGiving all.
Thanks.
okiloveu is offline   Reply With Quote
Old 11-23-2006, 12:36 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I think the procedure is in the owner's manual. But guessing that your car is similar to mine, you unclip the rear cover from the lamp (two wire clips), then remove the bulb. You don't say which bulb it is. The small one twists 1/4 turn and removes, the large one is held in with a wire clip. You might as well do both sides.
Old 11-23-2006, 01:08 PM   #3 (permalink)
amcnair's Avatar
Date registered: Mar 2006
Vehicle: 1997 E420
The one on the left also requires the removal of the washer fluid reservoir before you can get to the cover.
amcnair is offline   Reply With Quote
Old 11-23-2006, 03:40 PM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
all you have to do is pull & lift the reservoir and you can gain access. and yes it is in the owners manual.
JOE55 is offline   Reply With Quote
Old 11-23-2006, 11:29 PM   #5 (permalink)
Date registered: Jul 2006
Vehicle: 98 MB E320
Lol, I just take out the whole headlight. Iv'e done it so many times that I can do both in 5 minutes :$
di_nate is offline   Reply With Quote
Old 11-24-2006, 01:09 AM   #6 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
i'm with nate on this. :-) besides, i dont have a body or arms like Gumby.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
how to replace back-up light bulb? ProV1x W210 E-Class 1 11-05-2006 10:34 PM
How do I replace headlamp bulb. Darkmann W210 E-Class 2 10-31-2006 10:46 PM
How to replace headlight bulb msmmgr R170 SLK Class 2 10-11-2006 07:24 AM
how to replace bulb in headlight switch mr diesel W123 E,CE,D,CD,TD,TE Class 2 09-12-2006 09:26 PM
NEW USER > HOW TO REPLACE THE BULB in DRIVER SIDE FRONT HEADLIGHT?? yak W220 S-Class 0 03-21-2006 09:22 AM
