» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Closed Thread
Old 11-29-2006, 10:35 AM   #11 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Diff Oil Change Interval
Well, I did search the WIS, and there is NO specified interval.
On the G's, there IS a recommended interval of 60,000 Mi. Granted, it's under much more strain than the E, but it's the interval that I feel is "reasonable."
To me oil is cheap, and it's easy to change, so why not?
Also, the spec sheet now allows sythetics for diff's.
G-AMG is offline
Old 12-27-2006, 05:15 AM   #12 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
One of your picture/photo indicated to torque the drain plug to 80 NM. Shouldn't it be 50 NM?
cerritos is offline
Old 12-27-2006, 08:04 AM   #13 (permalink)
G-AMG's Avatar
Torque Values
According to my WIS, the DRAIN plug is to 80 Nm, and the FILL plug is to 50 Nm.
It is similar on the G as well.
G-AMG is offline
Old 12-28-2006, 07:38 AM   #14 (permalink)
Vehicle: 2001 E320
For some strange reasons, I can't find drain plug torque value in WIS. I saw references of 50 NM (36.8 pound foot) for filler plug.
When I changed the differential fluid on my 2001 E320 two days ago, I used 50 NM for the drain plug and it matched the original position that I marked before I removed the plug. I did not go any further in fear of stripping the thread. I sure don't want to pay the dealership to replace the differential for a stipped thread. I'll watch out for leaks though.
80 NM equals to 59.0 pound foot. That's a lot of torque. I wouldn't torque it that much.
50 NM (36.8 pound foot) is a reasonable torque for that size of plug. The filler and drain plugs look identical to me. I wonder why WIS specifies different torques for the same size plugs.
BTW, the original differential fluid (35K miles) are so dirty, it looked like mud. I'm so glad that I changed it.
cerritos is offline
Old 12-29-2006, 08:07 AM   #15 (permalink)
G-AMG's Avatar
Oil Change
Cerritos,
The sludge that does come out makes one wonder why we don't change it more often, Eh??????
Did you notice a quieter rear end after changing the oil?
What brand did you end up going with?
Were you able to track down that "Optiseal"??
I guess the higher torque value on the drain screw is due to the fact it is the dependent position, and needs to have a tighter seal.
On the G, I believe the split was 60 Nm on the fill side, 70 on the drain.
G-AMG is offline
Old 12-29-2006, 08:58 AM   #16 (permalink)
Vehicle: 2001 E320
Hi, G-AMG,
Personally, I will change it every 30k miles. I don't understand why MB does not specify the frequency of changing this oil.
I have low miles (35k miles), so, I did not notice any change of noise. I changed the oil because I want to keep it in a good shape, not because there was a problem.
I ended up with Mobile 1 synthetic. I was very disappointed with Mobile 1 though. I used a clear vinyl tube extended outside of the car. So I was able to pour the oil into this tube and was able to see the oil while it's being fed into it. Occasionally I saw "air bubbles" in the fluid and did not mind with it. However, when it approaches the end of the bottle, there were tons of "air bubbles". That made me aware that they were not air bubbles after all. They are contaminants. In other words, mobile 1 synthetic has debris at the bottom of the bottle. However, I tried to use my finger to feel the "hardness" of these debris in what were left in the bottle and can't feel anything (They were visible though). I guess they're harmless. But I'm very disappointed with Mobile 1. I will try Red Line next time. Maybe I'll use MB's oil even though it's much more expensive.
I used Permatex High Temperature Thread Sealant (Part number 59214). It's available at Autozone. MB's Omnifit Sealing Compound 100H (A 003 989 18 71 10) is available at the dealership via special order (House of Imports, CA).
I was not able to find any reference of the torque value for the drain plug. Could you provide a pdf/word or just a screen capture of the document? This way, I can understand whether I under torqued it or not. I hope it's not too much trouble. Thanks.
cerritos is offline
Old 12-29-2006, 09:38 AM   #17 (permalink)
Musikmann's Avatar
Lightbulb W210 Differential Oil Interval
Originally Posted by cerritos
FSS does not specify when to replace rear differential fluid. Should we do it every 30k miles? 60k miles? or 100k miles?
I just spoke to my dealer's service department, and their policy is that this is part of their approximately 80,000 mile service.
Musikmann is online now
Old 12-29-2006, 06:01 PM   #18 (permalink)
Vehicle: W210 E300TD
Did you service the breather valve on the top of the differential? This is a job I need to do, just wondering how easy it is to reach.
Parrot of Doom is offline
Old 12-29-2006, 07:37 PM   #19 (permalink)
II kings 920's Avatar
Date registered: Dec 2006
Vehicle: '00 S430
Great write up, I plan to do mine soon. Does the S430 also use 75W90? My guess is yes..
One point I would like to add. Always loosen the fill bolt first. If for some reason you are unable to loosen the fill bolt and all the diff fluid has been drained out then you have a real problem on your hands with an empty diff. Same applies to 4WD transfer cases.
If the bolts were torqued to spec and not cross threaded then there should be no problems (Murphy's Law). I did my MDX and had to use a rubber mallet on the ratchett to loosen all for drain bolts. I almost had to resort to my air impact wrench. They were way beyond the 33ft/lb specs.
II kings 920 is offline
Old 12-29-2006, 08:26 PM   #20 (permalink)
G-AMG's Avatar
OOPS, Egg on My Face
Folks, Especially Cerritos!
I feel terrible. Reading the WIS off my small laptop, and, perhaps a need for glasses!!,
I DID incorrectly read the torque value for the DRAIN plug. It SHOULD ALSO be
50 Nm. A thousand pardons.
To answer the one point, though, these type of bolts are not so delicate. The G's front differential drain and fill screws are to 100 Nm!!
G-AMG is offline
Closed Thread
Photo Diy Of Fuel Filter Change G-AMG W210 E-Class 54 10-11-2009 04:45 PM
DIY - Differential Fluid Change netdvn W210 E-Class 17 09-22-2009 06:49 PM
Anyone have a DIY for a rear differential fluid change and seal replace? jtoma878 W208 CLK Class 0 01-24-2006 06:39 PM
Rear differential oil change on SLK32 AMG32 R170 SLK Class 4 01-29-2002 07:19 PM
Recommendation: Change the oil of rear axle differential at about 3000-4000 mls Tim CH R170 SLK Class 7 09-18-2001 02:01 PM
