» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 11-20-2006, 10:22 PM   #1 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Photo Diy Of Fuel Filter Change
Greetings all.
Since I recently had to change out my '98 E320 Fuel Filter, I thought I would share it (photographically) so you can see it's not a difficult job, even for a novice mechanic like myself. I claim no expertise, and am just following the WIS procedure.
Enjoy, and comments are always appreciated!
G-AMG is offline   Reply With Quote
Old 11-21-2006, 04:50 AM   #2 (permalink)
jka
Date registered: Aug 2006
Very nice!
Thank you.
jka is offline   Reply With Quote
Old 11-21-2006, 11:07 AM   #3 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Good to see use of German tools!
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI, '06 SLK350
Old 11-21-2006, 03:42 PM   #4 (permalink)
Date registered: Oct 2006
Vehicle: 1997 E420
Is this the same with the 97 E-420?
will420 is offline   Reply With Quote
Old 11-21-2006, 07:22 PM   #5 (permalink)
osdesierto's Avatar
Date registered: Oct 2004
Vehicle: W201, W202, W210, E53
Send a message via AIM to osdesierto Send a message via Yahoo to osdesierto
fuel lines clamp is nice to have.
osdesierto is offline   Reply With Quote
Old 11-21-2006, 08:01 PM   #6 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
It is very nice of you to share actual experience you went through. I thank you very much. It will be very helpful.
Raylee177 is offline   Reply With Quote
Old 11-21-2006, 08:46 PM   #7 (permalink)
G-AMG's Avatar
will420
According to my EPC (I took excerpts for you, comparing my E320 to the E420).
It actually looks much easier, as your fuel pump is back at the fuel tank, and there is only ONE fuel line going IN, and only ONE going out.
Just jack her up, pull off 3 bolts, and you'll have your answer!
Sorry my photo editer won't do GIF files, otherwise I would point things out for you.
Let me know if it's not clear, and I'll be happy to assist.
Old 11-22-2006, 01:32 AM   #8 (permalink)
sleman22's Avatar
Date registered: Apr 2006
Vehicle: e430 2000
Send a message via Yahoo to sleman22
WoOoOoOoW
SO NICE MAN .
THANK YOU !!!!
sleman22 is offline   Reply With Quote
Old 11-22-2006, 07:21 AM   #9 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
3 questions:
1. what is WIS you are talking about?
2. Does gas spill out when you disconnect the hoses?
3. the yellow font in the middle 2 pics is hard to see..
Thanks again !! This looks easy, I will definitly do this myself next spring.
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 11-22-2006, 09:25 AM   #10 (permalink)
G-AMG's Avatar
Answers:
1. WIS (Werk Informacion System) is the "Electronic Manual" for DB. They literally have the shop manuals for every model from 1960 something, all the way until now, including Maybach, Dumptrucks, buses, etc. Its what Mercedes techs use. They are readily available on Ebay. Instead of having the '07 models, the Ebay discs are great, and don't cost the $1,000 the dealer wants. They run around $25 USD. They are huge, 8 GIGS. Also available on Ebay is EPC (electronic parts catalogue), just like the excerpts shown above. Again, they have every part, for every car, every year you can imagine, again, 6 GIGS, and also run about $25.
2. The photo you can't read (sorry!!!) fuel line clamps are placed on the FRONT two lines which are the "IN" lines (one from gas tank, one from fuel pump). The
"EXIT" lines are not under any pressure, so +/- if you want to clamp them.
3. SORRY!
DIY - air filter change BF_JC230 W203 C-Class 27 11-01-2009 05:41 PM
fuel filter change and no go kiva diesel W126 S,SE,SEC,SEL,SD,SDL Class 15 08-08-2009 01:36 PM
Fuel filter change DIY added to the knowledge base Brett San Diego W140 S-Class 0 11-20-2006 10:00 AM
Fuel filter change bcool R129 SL Class 2 09-12-2004 01:01 PM
Fuel Filter Change MLMoose W163 M-Class 0 08-06-2004 03:51 PM
