» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 06-05-2009, 04:27 PM   #51 (permalink)
Date registered: Jun 2009
Vehicle: 2000 S500
Thanks. I'll change the fuel filter (I have it) and order the CPS.
Jeff Sanford is offline   Reply With Quote
Old 10-11-2009, 03:13 PM   #52 (permalink)
Date registered: Jan 2008
Vehicle: W210 1996 E320 Exterior Smoke Silver, Interior Mushroom
Whereis my fuel filter
AlldataDYI.com says about the location: "Frame floor ahead of rear suspension in fuel pump assembly or similarly located on the left of frame floor in front of rear suspension, suspended separately on rubber rings.".
I removed the protective panel on the rear passenger side, in front of the rear suspension but cannot find the fuel filter as the pictures show. It is a 1996 E320.
It is quite elusive for a part as big as Muhamad Ali's fist
W210 1996 E320 Exterior Smoke Silver, Interior Mushroom, 159,999 miles as of 09/09/09.
texholdem is offline   Reply With Quote
Old 10-11-2009, 03:53 PM   #53 (permalink)
Witek_M's Avatar
Date registered: Sep 2008
That is not jack point and << is pointing to suspension rear right.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline   Reply With Quote
Old 10-11-2009, 04:08 PM   #54 (permalink)
I was jacking up the wrong side, how stupid! , just checked: Left = Driver side and Right = Passenger side. )
So the tank is on the right side and the filter on left side, correct?
2 hours wasted
Old 10-11-2009, 04:45 PM   #55 (permalink)
Witek_M's Avatar
2 hours wasted
Left side is one with letter "L" on the tail light. There are countries where they drive on the wrong side of the road so driver/passenger is not best use.
Fuel tank sits upright behind rear seat.
DIY - air filter change BF_JC230 W203 C-Class 27 11-01-2009 05:41 PM
fuel filter change and no go kiva diesel W126 S,SE,SEC,SEL,SD,SDL Class 15 08-08-2009 01:36 PM
Fuel filter change DIY added to the knowledge base Brett San Diego W140 S-Class 0 11-20-2006 10:00 AM
Fuel filter change bcool R129 SL Class 2 09-12-2004 01:01 PM
Fuel Filter Change MLMoose W163 M-Class 0 08-06-2004 03:51 PM
