Old 08-25-2008, 05:41 PM   #31 (permalink)
nugent's Avatar
Date registered: Jul 2005
Vehicle: Self: 2000 E320 83,000 mi Girlfriend: 1998 E320 134,000 mi
CLIC clamp removal
Time to change my fuel filter, which has the Clic clamps. How do I remove these clamps without using the Hazet tool?
I don't want to buy the tool just for this simple job. I will use jubilee clamps to re-attach the hoses.
nugent is offline   Reply With Quote
Old 08-26-2008, 04:37 AM   #32 (permalink)
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: 1998 E320 Wagon
Have you tried your local "Parts-o-rama" store? A lot of places around me in Atlanta (Autozone, AdvanceAuto, Oreilly, etc.) will loan tools for a deposit. I am sure they have something that will do the trick.
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
TNTRower is offline   Reply With Quote
Old 11-08-2008, 11:18 AM   #33 (permalink)
bcald's Avatar
Date registered: Jan 2006
Vehicle: 2001 E320
Send a message via Yahoo to bcald
Great post. I had bit of a difficulty with the orginal hose clamps, but once I figured out that if you squeeze them a bit they spring open, it was a breeze after that.
bcald is offline   Reply With Quote
Old 11-09-2008, 08:40 PM   #34 (permalink)
Date registered: Jan 2008
Vehicle: W210 1996 E320 Exterior Smoked Silver, Interior Mushroom
Thanks, I gonna give it a try. Hopefully it is the same with my 1996 E320.
Just another question: what are the signs for a fuel filter to be replaced? Or can I replace it as a preventative maintenance?
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
texholdem is offline   Reply With Quote
Old 11-10-2008, 12:19 AM   #35 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Same setup on your 1996. Filter is a 60,000 mile interval, can cause idle, starting and driveability issues when it needs to be changed. When badly clogged it can cause excess backpressure that damages the fuel pump. You can change it whenever you like, autohausaz.com has them on sale right now.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 11-21-2008, 01:00 AM   #36 (permalink)
Date registered: Nov 2008
Hello all... great forum and lots of helpful inormation..
I need to replace on my 1994 E320 the FUEL HOSE due to leaking. this FUEL HOSE is between the fuel feed line and the fuel filter. is this hard or easy to do. can it be done at home. and how do you stop/plug /clamp the fuel feed line or the fuel filter.. any special tool needed here.
thanks for the advice and help..
life101 is offline   Reply With Quote
Old 11-21-2008, 02:55 PM   #37 (permalink)
gregs210's Avatar
Hi, life, welcome to the forum. Please click the user cp link and complete your BW profile re: vehicle and location as that is often useful information.
This forum is for the W210, and you own a W124. There may be some people here who can answer your question with detail, but you are better off posting a new thread in the W124 forum instead of hijacking someone else's thread. I'm sure the knowledgeable folks in the 124 forum can help you out.
Greg
Old 11-26-2008, 11:38 PM   #38 (permalink)
Date registered: May 2008
I replaced my fuel filter today for 3 hrs. The filter has the same set up as Thread #24 above. It is on my E320/2001 wagon. I pull the fuse #6 for fuel pump from my fuse box near the battery under the rear passenger seat. Use some cloth wrap around the fuel lines from the tank and pump and clamp it with two vise grips. The fuel came out of the pressure side is about 6 OZ. I release the clic clamp by a nail pier, just squeezed the clamp, it will open up. I replace the clic clamp with fuel injection hose clamps.I purchased a box with 12 for $6 from O'Reilly. There are 6 in 16mm and 6 in 14mm. The 14mm will fit the fuel line from pump and motor. The 16mm will fit the tank fuel line. The clamp just look like the clip in the original thread picture of the Thread #3 above. Afterward, I test drive the car at 95 miles in the freeway and everything is normal.
E320 Waggon 2001 W210.265
S500 2000 W220
Porsche 997 C2S Coupe 2006
TIPTRONIC, GPS, PHONE
500SEC 1984 retired at 192K
Porsche 928S GT 1984 (euro) retired at 243K
ML320 1998 retired 43K (wife accident)
daisound is offline   Reply With Quote
Old 11-26-2008, 11:48 PM   #39 (permalink)
Before I clamp the fuel hose I took out the fuss for the fuel pump. I think this is a back up to ensure the fuel is cut off even the line may not be completely clamped. I actually selected a section of straight soft section of line to set up the clamp. That way you will not break the line by the clamp. So, do not clamp the line at the loop from the pump side.
DIY - air filter change BF_JC230 W203 C-Class 7 11-05-2008 07:00 PM
fuel filter change and no go kiva diesel W126 S,SE,SEC,SEL,SD,SDL Class 7 07-15-2007 01:00 AM
Fuel filter change DIY added to the knowledge base Brett San Diego W140 S-Class 0 11-20-2006 10:00 AM
Fuel filter change bcool R129 SL Class 2 09-12-2004 01:01 PM
Fuel Filter Change MLMoose W163 M-Class 0 08-06-2004 03:51 PM
