Old 11-17-2006, 06:21 AM   #1 (permalink)
osdesierto's Avatar
Date registered: Oct 2004
Vehicle: W201, W202, W210, E53
Send a message via AIM to osdesierto Send a message via Yahoo to osdesierto
1 Malfunction
OK This came up twice now but in a period of 2 months... Lamp - I checked it all and it seems to be all working - in and outside. What could it be?
osdesierto is offline   Reply With Quote
Old 11-17-2006, 07:45 AM   #2 (permalink)
OBX884's Avatar
Date registered: Sep 2002
Vehicle: 01 E320 4MATIC Wagon
Probably bad sockets... the lights still work but the warning comes on, right?
'86 560SEC ('97 E420 & '01 E320 4MATIC Wagon)
OBX884 is offline   Reply With Quote
Old 11-17-2006, 11:53 AM   #3 (permalink)
osdesierto's Avatar
exactly -- how can I pinpoint which one... sigh
Old 11-17-2006, 02:08 PM   #4 (permalink)
amcnair's Avatar
Date registered: Mar 2006
Vehicle: 1997 E420
First, check the marker lights on the side of the bumper. Lots of people (myself included) thought they had all bulbs working, but did not look at those. Also, check the license plate lamps.
amcnair is offline   Reply With Quote
Old 11-17-2006, 02:33 PM   #5 (permalink)
Date registered: Oct 2006
Vehicle: 1998 E320
Triple check all!! Do not forget the trunk light, underhood light, and the license plate lights (as amcnair stated). You'd be surprised what one might overlook. Occasionally I have a "lamp defective" come on. I know it is a loose connection on the leftside/front lamp (not the headlight, the other one). I give it a tap, and the light comes on. Just haven't gotten under the hood to fix yet. Check all the interior lights too, especially the rear.
Texas is offline   Reply With Quote
Old 11-17-2006, 07:32 PM   #6 (permalink)
osdesierto's Avatar
thanks guys, i will do a thorough check this weekend
Old 11-17-2006, 09:17 PM   #7 (permalink)
Date registered: Nov 2006
Vehicle: 2001 E320 4Matic
I just had similiar issue. I checked the main bulbs but did nto realize I could have loose connectors on bulbs for license plate and side markers.
Checked all the bulbs listed, none out. Turned car on & all worked but then warning came on again. Just for kicks I tapped on a few and now the warning went away. Problem is I did not make note of which was loose.
das_benz is offline   Reply With Quote
Old 11-18-2006, 08:17 PM   #8 (permalink)
osdesierto's Avatar
i found the culprit, right brake light...
Old 11-19-2006, 06:10 AM   #9 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Common issue - mine just went out a week or so ago. Every year or so it happens. What I do is have my wife step on the brake pedal while I rotate the bulb in the holder until I find the sweet spot. Some folks have built up the contact area. Some have replaced the entire holder unit. I choose the cheap/easy method.
Len
sokoloff is offline   Reply With Quote
Old 11-19-2006, 08:32 AM   #10 (permalink)
Date registered: Jun 2005
Vehicle: 1998 E320
Post
I had several go when I first picked up the car. As they were replaced I would have the base coated w/dielectric grease. It is non-conductive, but when you slide the connectors together there is metal-to-metal contact, the grease gets displaced, and the area around the connector is protected from moisture.
I have not had any warnings in a year now. Knock knock knock...
Bob
bob98e320 is offline   Reply With Quote
1 malfunction iceman28o1 W208 CLK Class 1 08-26-2005 06:59 PM
Malfunction With A/C S_Class_Don W126 S,SE,SEC,SEL,SD,SDL Class 9 07-27-2005 06:59 AM
1 malfunction Old Otto W210 E-Class 11 06-15-2005 07:13 AM
First Malfunction RonJeffries R171 SLK Class 0 04-15-2005 05:51 PM
1 Malfunction ????? Guest (MBNZ) W203 C-Class 2 07-08-2002 06:37 PM
