Old 11-15-2006, 08:48 AM   #1 (permalink)
Date registered: Jul 2003
Leaking oil pressure port
I have been experiencing an oil leak from the front of the engine of my '98 E320. I think I have identified the culprit as the oil pressure port plug/cover (also refered to as a "timing case expansion cover", anyway, see the attached picture if you are still wondering what I am talking about. Replacing the gasket seems like an easy enough thing to do, my question is: what has caused this leak? Should I be checking for a malfunctioning PCV (ie., did a pressure buildup in the crank case cause this gasket to fail)? Any thoughts on root cause, or is this just one of those things that eventually happens?
cheers...
kreb is offline   Reply With Quote
leaking oil pressure gauge on cluster mr diesel W123 E,CE,D,CD,TD,TE Class 10 08-01-2007 11:41 PM
Oil Pressure Gauge Leaking.... Drumboy W123 E,CE,D,CD,TD,TE Class 1 07-24-2006 10:18 AM
1 quick question: which A/C port is low pressure one? Anjey W126 S,SE,SEC,SEL,SD,SDL Class 7 02-02-2005 12:35 PM
Leaking low Oil level, and pressure senders.. Big D W126 S,SE,SEC,SEL,SD,SDL Class 1 04-02-2004 08:29 AM
oil dipstick port militarypress W203 C-Class 2 02-25-2004 08:29 PM
