» Site Navigation | | » Other Sites | » Search Used Cars | |
| » Network Links | | | | » Wheel & Tire Center | | | | Sponsors | | | |
11-15-2006, 05:49 AM
#1 (permalink)
| | BenzWorld Junior Member
Date registered: Sep 2004 Vehicle: 97 E320 Location: Cheektowaga NY
| Brake Replacement ? Hi
I read a tread that had the answer to this question but now I cannt find it, so here it is
What size are the bolts on the caliper and what paste do I need for the anti squeek? I have a 97 e320 Thanks Mike |
| Advertisement
11-15-2006, 10:15 AM
#2 (permalink)
| | BenzWorld Elite
Date registered: Dec 2005 Vehicle: E300DT/320cdi ML320/55 Location: CA Bay Area
| I believe you need 7 mm hex for the bolts. MB usually don't need brake paste, but if you want to use any, I always liked the spray on stuff. |
11-15-2006, 10:44 AM
#3 (permalink)
| | BenzWorld Elite
Date registered: May 2005 Vehicle: '07 GL320CDI, '06 E320CDI Location: Albuquerque
| On the REAR of my E320S, the caliper bolts require 19mm wrench.
The hex head screw holding rotor to hub is 6mm
Use Mercedes pad grease--always.
Kent Christensen
Albuquerque
11-18-2006, 08:11 AM
#4 (permalink)
| I thought I read about a red paste that helped with squeeking |
| Advertisement
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | |
