Old 11-15-2006, 12:56 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1997 W210 E280; 1979 W123 250
Erratic cruise control
Hi Everyone,
I had my E280's transmission rebuilt last month. It was well worth the expense, as it shifts smoothly now. However, I had my first long trip this weekend and then noticed that the cruise control is erratic. Sometimes it refuses to engage, or it will engage but then disengage by itself after a while. Then there were also times where it worked perfectly for long periods, but would then suddenly just disengage and refuse to re-engage.
Does anyone have an idea of how to fix this?
wmerc280 is offline   Reply With Quote
Old 11-15-2006, 05:09 AM   #2 (permalink)
Date registered: Nov 2006
Your cruise control amplifier is failty, at www.cruise-control-repair.tk you can find more info.
tempomat is offline   Reply With Quote
Old 11-15-2006, 06:23 AM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I didn't think there was a cruise control amplifier as a separate part on his car.
Old 11-16-2006, 01:47 AM   #4 (permalink)
ok, I am not shure if this type has a separate cruise control amplifier, it could also be that the cc amplifier is integrated in the ecu. When this is the cause I would suspect that the part of the ecu that controls the cruise control is failty. But he has first to check al switched (brake, cloutch, on/off etc), that could ofcourse also explain it. But the VDO systems in Mercedes with this kind of behaviour has often problems with the amplifiers and these can be remanufacterd, see the link as mention before.
Old 11-16-2006, 02:59 AM   #5 (permalink)
Vehicle: E320 2002, VW Passat 2003, Toyota Landcruiser 2007
I think you need to check the brake switch first because it's the cheapest (around $15-20), I had a W210 97 before and I had a similar problem in my cruise control, the next to check if not the brake switch is the accelerator which's underneath the air intake, in this model (M104 engine) it's the most part that can go wrong in cruise control parts but it's a bit expansive that's why I didn't do in my old car, in fact I sold the car, anyway I believe in (W210) 96-97 models they still have a module for cruise control in the ECU box, but from 98 and above it's integrated in the ECU of the car after they introduced the V6 engine (M112).
anyway it's just an openion.
good luck
farsal is offline   Reply With Quote
Old 11-23-2006, 10:43 PM   #6 (permalink)
Erratic cruise control follow-up
Hi Guys,
Thanks for the replies on my post. My trusty mechanic has diagnosed the control unit (arm & switch) as the culprit. Cost me about $130 to replace. I'm picking the car up this afternoon & will let you know whether the problem is solved.
Thanks for a great forum
Erratic Volume Control sbou101 W140 S-Class 27 10-27-2006 11:20 AM
My Volume Control Knob Erratic Behavior... davaid Audio & Telematics Forum 1 10-09-2006 09:33 PM
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK Class 42 01-15-2006 02:37 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 10:51 PM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 10:34 AM
