Old 11-13-2006, 12:30 PM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
M119 oil guide replacement part list?
My 97 E420 has been ticking for a while but since yesterday, it's ticking so loud that you could hear the car from a block away. It's quite embarrasing, and scary!! Sounds like a ticking bomb.
I'm going to follow the DIY guide in the "DIY Articles" section, but if you own a M119 motor and have done this previously, could you please post a complete list of all the parts I need to order? Both for absolutely necessarry parts and stuff that you'd recommend replacing. Thanks!!
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 11-14-2006, 06:34 PM   #2 (permalink)
Date registered: Feb 2005
Vehicle: '97 E420 Sport Brilliant Silver
ProV1x, I feel for you. It's very common on our '97 E420 around 100k miles. It happened to me right at 105k also. I hear it happens like clockwork. ALL You will need is 16 cam oilers/guides (8 per side) and 2 valve cover gaskets for either side. Around $300+ in parts, but around a $1200-1400 job @ the dealer for both sides. I'm going to attempt to do it myself also, but I hear you have to be careful, could very easily screw something up......
TyBenzo is offline   Reply With Quote
Best source for 3.8 guide rail replacement bits? tucson_sailors W126 S,SE,SEC,SEL,SD,SDL Class 1 02-21-2006 09:44 PM
M119 Water Pump Replacement - any tips? rsmcmahon W140 S-Class 2 08-31-2005 01:17 AM
Brake support bearing/guide rod replacement rodmex W126 S,SE,SEC,SEL,SD,SDL Class 0 05-31-2004 12:44 AM
Timing Chain Guide Rail Replacement Litton W126 S,SE,SEC,SEL,SD,SDL Class 1 12-02-2002 09:43 PM
Timing Chain & Guide Replacement Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 08-02-2002 01:24 PM
