Old 11-12-2006, 09:27 AM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
Quick Q: how to bleed radiator?
good morning gents, i just drained the old coolant (i can tell it's been there for a while!), added 50/50 mix, let the engine run for a bit, drain again, and then added 50/50 mix (OEM MB fluid).
I'm a bit nervous about the MB cooling system coz i do not see an extra reservoir. anyway, i have the heater set at max and i've let it reach operating temperature. how do i make sure all the trapped air is purged from the system? thanks !
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 11-12-2006, 09:47 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Don't you have pressurized coolant reservoir on passenger side in the engine compartment?
You did fill the system, so you have a cap somewhere. Just recheck the level there. MB usually have a sensor waring about low coolant level.
Kajtek1 is online now   Reply With Quote
Quick help required on 560SEC radiator swap ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 10-11-2005 03:59 PM
clutch bleed diamondrill W123 E,CE,D,CD,TD,TE Class 0 04-17-2005 09:25 PM
Brake bleed sjtymko G-Class 11 04-07-2003 09:19 PM
How do you Bleed brakes Guest (MBNZ) W210 E-Class 3 04-17-2002 12:25 PM
How do I bleed the lockers? Steve D G-Class 1 03-14-2002 01:52 PM
