Old 11-10-2006, 11:43 PM   #1 (permalink)
Squeeky Steering Wheel
Recently the steering wheel on my 97 e320 has been squeeking. I noticed that it started squeeking after I had left the car in the hot sun all day & the temp in the car must have risen considerably. Any advice on how to keep it from squeeking? (Besides wd40)
Thanks!
JoeRose70 is offline   Reply With Quote
Old 11-11-2006, 11:32 AM   #2 (permalink)
Richard / E320's Avatar
Vehicle: 01 M-B E320
Thanks!
Mine did the same thing; I believe it's a known problem, and the dealer sprays lubricant around the steering column seal / area near the firewall.
Richard / E320
2001 M-B E320 / Glacier White / Java Leather / 18" AMG Style III & Bridgestone Potenza's
1987 M-B 420SEL / Impala Metallic w/ Palomino Leather
Richard / E320 is offline   Reply With Quote
Old 11-11-2006, 08:16 PM   #3 (permalink)
Date registered: Nov 2006
Vehicle: 2001 E320 4Matic
I had the same problem, 1.5 years ago, on my 01 E320. Dealership said I needed new control arms, I believe that is what it was - it was under warranty.
- Had them replaced, noise came back 4 to 6 months later.
- Took it back in during last service and it stopped. It has been about 5 or 6 months since service and it has started again.
HMMMMM
They may be simply placing oil drops and it works for another 6 months!! I can not get a real answer from the dealership!
das_benz is offline   Reply With Quote
Old 11-11-2006, 11:34 PM   #4 (permalink)
olivengco's Avatar
Date registered: Oct 2004
Vehicle: 2000 E320
I had the same problem 1 year ago with mine, kept going back to the dealer for lubricant around the steering column seal and the noise kept coming back after a month. Finally they decided to replace the rack and pinion. It has been a year now and the noise hasn't came back.
olivengco is offline   Reply With Quote
Old 11-12-2006, 12:29 AM   #5 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
the squeeking steering anomaly seems to be quite the recurring theme for W210s
but for a variety of reasons. I can prob come up with the TSB for your model/year
if you PM me the info.
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 11-12-2006, 08:56 AM   #6 (permalink)
Date registered: Nov 2005
Vehicle: 1991 190E 2.6 (sold), 2002 E320 4Matic, 1991 300SL, 2004 Volvo V70 titainium edition
My '02 E320 does the same thing. I read about it in the common problems section of www.eclassbenz.com. They say it is a worn bushing on the power steering box. The bushing can be replaced, although some dealers may try to sell you a new power steering unit.
james54 is offline   Reply With Quote
Old 11-12-2006, 11:41 PM   #7 (permalink)
olivengco's Avatar
Vehicle: 2000 E320
I had a feeling it might have been something in the power steering box and not the rack and pinion. The service guy at my dealer thinks it might be the rack and pinion and wanted to replace that, but since my car was still under warranty I just asked the service guy to replace the power steering box too at the same time they replaced the rack and pinion. In my opinion by having the power steering box replaced solved the squeeky noise and not the rack and pinion.
Old 11-13-2006, 10:19 AM   #8 (permalink)
fju2112's Avatar
Vehicle: 2002 E320 4Matic, 101K miles as of 7/2008
i have this problem in my 430. of course i want to try using a silicone spray on it before i take it anywhere. where exactly do i spray, or is it not accessible unless i take the wheel off?
fju2112 is offline   Reply With Quote
Old 11-30-2006, 08:56 AM   #9 (permalink)
one.bofh's Avatar
Date registered: Jul 2006
Vehicle: 2001 E320
My steering wheel started squeaking as well just recently... Same as fju2112, I would like to try spraying silicone or wd40 on the wheel column... How do I access it? TIA.
I haven't lost my mind - it's backed up on a tape somewhere.
one.bofh is offline   Reply With Quote
Old 11-30-2006, 05:54 PM   #10 (permalink)
netdvn's Avatar
Date registered: Oct 2005
Vehicle: E-Class, SLK
The sqeeking noise from the steering wheel is on and off on my E320 for about a year now. Instead of fixing it, I ignore it.
Take it easy!
Netdvn
netdvn is offline   Reply With Quote
FS/Trade:CF Steering Wheel for W203/WTB:CF Wheel for my W211 skeeter66 For Sale, Trade & Wanted Items 0 08-24-2006 08:56 AM
squeeky steering wheel? bighamsterneck W163 M-Class 2 11-21-2005 11:52 AM
Squeeky Steering wheel olivengco W210 E-Class 5 12-16-2004 11:52 AM
Is there an aftermarket steering wheel that has the horn in the center of the wheel? DaveS R170 SLK Class 10 06-09-2003 07:01 AM
Steering Wheel Vibration - No Problem With Wheel Balance Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 04-02-2002 09:28 AM
