Old 11-07-2006, 06:09 PM   #1 (permalink)
Date registered: Nov 2006
Exclamation Check engine electronics, Check oil level.+ others
My car is a 1996 E320 sedan with 162k miles. Recently I saw engine oil level, soon after check engine electronics came up. I checked the oil level, it was ok. I went ahead and did oil change and changed the oil swtich in the pan. All to no avail. All this while its performance was not compromised. About a week ago it started to mis fire and my mechanic said I should do tune up which I did. Right now it fires well, But when i start it in the morning, the initial crank was high as if one steps on the gas pedal. this is associated with a tapping sound that stops after warming up. Its like a bundle of problems all coming at the same time. I have heard about engine harness and I dont want to think along that line because of the "Benjamin" I also hear the humming of the trans as it selects the gear. This is worse at low speed 20-40. Please your sugestion is despirately and urgently neede. This car is driving me crazy. Do I forget to tell you I still love this car?
bondale is offline   Reply With Quote
Old 11-08-2006, 10:14 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
If you get a check engine light, get the code read to find out what the problem is. You can get the code read for nothing. Don't just guess and throw parts at the problem. That can get very expensive very fast. If your mechanic did not read the codes like he should have, get a new mechanic.
Len
sokoloff is offline   Reply With Quote
Old 11-08-2006, 07:52 PM   #3 (permalink)
Smile RE:check Engine
Thanks Len . I will go the dealer for the diagnosis.
Old 11-08-2006, 11:40 PM   #4 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
One visit to a dealer will cost you more, than a good quality scanner. I just bought one at PepBoys for $99 minus $20 rebate.
I am having my E300 displaying "engine electronic" code, what is some bad spot on gas pedal switch. It happens only occasionally, so I am not worry yet.
Good luck to you
Kajtek1 is online now   Reply With Quote
Old 11-10-2006, 12:28 AM   #5 (permalink)
Thanks .Does the scan comes with codes interpretation?
Old 11-10-2006, 01:02 AM   #6 (permalink)
Kajtek1's Avatar
Yes. The one I bought displays the full code meaning on the screen.
It come with CD as well, but I didn't open it yet.
"Check Engine Oil Level" though E320 runs fine? jayanta_sen W210 E-Class 5 12-25-2005 09:54 AM
Alert: Check Engine Oil Level MLSONIC W164 M-Class 5 10-08-2005 08:31 AM
how to check engine oil level and tranny ? drebdy W140 S-Class 3 06-27-2004 11:39 AM
Check engine - electronics JohnR W210 E-Class 4 02-26-2004 07:05 PM
Check engine electronics msg mb-mopar_nut W210 E-Class 2 12-03-2003 09:45 AM
