Old 11-04-2006, 04:32 PM   #1 (permalink)
Date registered: Nov 2006
E320 only starts in Park the position
I have a 1996 E320 and this morning, I tried to start my car but it would not start. I thought the problem was battery, but the lights, radio, and heater all came on after I turned the key in the ignition. Anyway, I decided to put the shifter in neutral and the car started.
I turned the car off and tried to restart the car in the park but it would not start. I put the shifter in neutral and the car started with no problem.
Does anybody know what can cause this problem?
Thanks,
Johnsteve
johnsteve is offline   Reply With Quote
Old 11-04-2006, 04:56 PM   #2 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Neutral safety switch
Kent Christensen
Albuquerque
Old 11-04-2006, 05:54 PM   #3 (permalink)
Smile
Thanks for the information.
Is the Netural Safety switch expensive repair?
Old 11-05-2006, 07:46 AM   #4 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
It is not a biggie, but is there anything cheap on MB, I would think 1hr, +part.
Peter Guenther is offline   Reply With Quote
Old 11-05-2006, 01:25 PM   #5 (permalink)
Okay
Where is the crankshaft position sensor located on a 99 e320 4matic??? 007MB1 W210 E-Class 1 09-09-2006 11:55 PM
1998 e320 starts then dies tarzancoe W124 E,CE,D,TD Class 4 09-07-2006 10:42 PM
Park position of headlight switch Bluebird W123 E,CE,D,CD,TD,TE Class 5 01-07-2006 03:49 PM
correct 'parked' position for '97 E320 wiper arm? xzz2343 W210 E-Class 2 10-02-2005 02:56 PM
Truck can be turn off and key removed without gear selector being at Park position trong_l W163 M-Class 4 08-13-2002 05:32 PM
