Old 10-22-2006, 05:26 PM   #1 (permalink)
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
what size socket do i need for the lower plastic engine cover?
i want to drop the plastic lower engine cover to replace the coolant and also engine oil.. my 10mm metric didn't fit. do i need a 8mm or something?? argh
ProV1x is offline   Reply With Quote
Old 10-22-2006, 05:53 PM   #2 (permalink)
deltajetfixer's Avatar
Date registered: Oct 2003
Vehicle: All of 'em
Yep. 8mm.
2005 Pathfinder LE
1999 Mercedes E300DT
deltajetfixer is offline   Reply With Quote
Old 10-22-2006, 10:30 PM   #3 (permalink)
troy6363's Avatar
Date registered: Jun 2006
Vehicle: 1996 Mercedes Benz E320
when u change urs let me know how becuase i need to change my coolant and i dont want to take is to the shop
troy6363 is offline   Reply With Quote
Old 10-22-2006, 11:33 PM   #4 (permalink)
Date registered: Oct 2006
Just take the bottom plastic piece off, remove the reservoir cap, open the radiator drain plug ( it's on one corner and you inscrew it with your hand), drain the coolant from the radiator and reservoir.
Close the drain plug and fill the reservoir up to the full level and fill the radiator until the fluid reaches the top where its visible. Leave the reservoir cap off, start the engine and turn the heat on full blast. Add coolant while the motor is running keeping the radiator full. Do this for about 15mins. Put the reservoir cap back on and you're set. I used a gallon of Mercedes fluid and the rest distilled water.
inssane3gt is offline   Reply With Quote
Old 10-23-2006, 11:09 AM   #5 (permalink)
ProV1x's Avatar
Vehicle: E55 ///AMG
is there no extra coolant reservoir in mercedes's? i am used to taking the reservoir off to drain whatever's left in there.
also, is there an engine block drain plug somewhere??
Old 10-23-2006, 06:42 PM   #6 (permalink)
I think there are 2 plugs, but I didn't mess with them. I drained the radiator, filled with water only, let motor reach operating temp then shut off motor, drained and refilled with water/coolant.
Worth a look under the front plastic M111 engine cover David in Australia R170 SLK Class 5 04-20-2008 12:28 AM
Removing the Plastic Engine Cover ? - Help acw1975 W215 CL Class 1 06-02-2006 08:49 AM
what size socket to use on lug bolts misterjuice The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 04-28-2005 07:25 PM
Brush bar replace lower engine cover? JG W163 M-Class 2 12-17-2004 12:31 PM
socket size for C grill screws? kenyee W203 C-Class 3 10-07-2003 09:20 AM
