I’d like to say “Thank you” to texas-patrick, who prepared very good description for such of routine.
Major problem was access to upper bolts.
I bought tricky, flexible ratchet from Craftsman (Sears item #00944815000 Mfr. model #44815).
This tool works very well and allowed to replace both mounts much faster then method with opened wrench.
- Unplug the battery! Right engine mount located pretty close to starter and you could get electrical salute when you'll put your wrench in this area (don’t ask me why I know
- Slide off serpentine belt. (torx E10 to move auto tensioner)
- Unscrewed A/C compressor and slide it forward (torx E12)
- I unscrew lower bolts (soket 13mm) and after used floor jack to raise the engine approx on 1 ½”. After that you will able to reach both upper bolts (socket 16 mm).
Tools:
Sockets: 8mm (for engine splash guard), 10mm (to unplug the battery), 13mm, 16mm, 17mm (I tuke off front wheels)
Torx: E10, E12
Floor jack.
Piece of wood (2x4" and 1 foot long)
3/8” drive ratchets (generic and flexible),
torque wrenches.
