Old 09-29-2006, 01:32 AM   #1 (permalink)
elchivo21's Avatar
Date registered: Mar 2003
Vehicle: 2000 E55 AMG
Steering wheel buttons get stuck!
Hello everybody! I was wondering if anybody has the same problem as do. Those cool buttons on the steering wheel that let one change the radio station and other functions get stuck every once in while! Now, image driving and the silly button get stuck on high volume. Not cool! Is there a method of fixing this? Maybe cleaning the inside of the buttons with causing any damage? Thanks.
_______________________________________
"It's not a matter of picking your nose; it's a question of where you put the booger"
Currently Own:
2000 E55 AMG (Black Widow)
Previously Owned:
1987 300E (Ministry of Sound)
1983 280SE (Big Papa)
1984 190D (Little Red Devil)
elchivo21 is offline   Reply With Quote
Old 09-29-2006, 10:26 AM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Remove the air bag and then you can remove the switch and clean the contacts
Mark Cummins is offline   Reply With Quote
Old 09-29-2006, 10:40 AM   #3 (permalink)
harb's Avatar
Date registered: Nov 2004
Vehicle: 2000 E320
To remove the air bag, unscrew the two hex screws on the back of the steering wheel. You may want to disconnect the battery before you unplug the air bag and the multi-function buttons contact wires such that you won't set any faults. Also remember to re-synch after you reconnect the battery.
A related question:
My multi-function steering wheel buttons are sticky to the touch. I tried to clean them once and managed to peel the corner of the clear skin covering them. Now I have sticky and peeling buttons! Anyone with this problem or suggestions to fix? By the way, only the top left buttons have this problem.
Tony Harb
2000 E320
1990 300E
1986 380SE
1982 280SE
1977 280S
harb is offline   Reply With Quote
Old 09-30-2006, 05:37 PM   #4 (permalink)
FireFox31's Avatar
Date registered: Sep 2005
Vehicle: Green '02 E320 Wagon
I bet this would be shown at braingears.com under Dissassembly of the Interior Part 4, but the video is incorrect (showing part 6). Is that bit of video anywhere else? This is a link to the mirror http://w210.pietrzyk.net/disassembly_68inter_step4.htm
FireFox31
28k miles of happy motoring in my Benz
FireFox31 is offline   Reply With Quote
Buttons on the Steering Wheel get stuck! elchivo21 W210 E50 AMG, E55 AMG 0 07-11-2006 12:17 AM
Buttons on Steering Wheel shedding Impala1ss W208 CLK Class 4 06-09-2006 04:04 AM
CLK430 steering wheel buttons Jackie411 W208 CLK Class 7 07-12-2005 05:26 AM
Steering wheel buttons ssass24 W208 CLK Class 0 03-04-2005 08:15 AM
Steering wheel shift buttons 3000tlm R171 SLK Class 2 08-21-2004 07:29 PM
