Old 09-28-2006, 10:25 PM   #1 (permalink)
Date registered: Aug 2006
Traction Support: Ive searched and tried a bunch of stuff but im stumped
Basically the car is a 97 e320, car has been running fine for the last 3k miles that I have had it. Yesterday the car shuts off while im driving and EL. Traction Support comes up on the instrument display.
Now the car cranks and comes to where it is supposed to idle and shuts off immediatly. I left it overnight and started it in the morning and it ran for about 30 seconds and shut off. I read alot of peoples post where the traction support thing was related to a brake switch and a crankshaft position sensor, but noone seemed to have the stalling problem that I am having.
I figured the CPS made more sence in my case since it would be hard for the car to run without a crank signal so I replaced that today, started the car, it ran for 15 seconds and died. I did however note that the part that my mercedes dealer gave me is one number off on the CPS sensor from the original. The original reads
A 003 153 95 28 and the new one reads
A 003 153 96 28 the 95 and 96 is different, can this be causing the problem and the new CPS isnt compatible basically rendering my part replacement useless?
EDIT: I looked into the number format for benz and the two digits prior to the last digits is the version number of the part and the last two digits is the part, so i suppose they just gave me a newer version of the part that I needed, should work I guess... but it didn't
Im thinking im going to go ahead and change the brake switch but would this cause the car not to run. My next option after that is a new battery, since I read this solved some peoples problems.
Funny thing is I bought this car as a daily driver to accompany my Nissan 240sx track car which is consantly breaking due to abuse and lots of power and here I am going to the benz dealer in the nissan for parts, go figure.
virus77 is offline   Reply With Quote
Old 09-29-2006, 08:01 PM   #2 (permalink)
Changed the brake light switch and nothing happened, car is gettting towed tomorrow but suggestions are welcome, Ill post the resolution for anyones elses reference once I find out whats going on.
Old 09-29-2006, 10:57 PM   #3 (permalink)
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
what was the problem?
I hear if the car shuts off its a simple plug and play DIY repair. Its the CPS sensor
here is a link : http://www.benzworld.org/forums/w210...ghlight=sensor
DETANE is online now   Reply With Quote
Old 09-30-2006, 04:05 AM   #4 (permalink)
alrady changed that sensor, im not that lucky to have a quick fix, im cursed when it comes to cars.
Old 09-30-2006, 07:05 PM   #5 (permalink)
Got my car back, it was the air flow meter. I guess the traction control gives errors on almost any sensor that goes bad on benzes, pretty lame, whatever shes back up and running.
*Whole Bunch Of Stuff For Sale* Extreez For Sale, Trade & Wanted Items 1 09-29-2006 11:00 PM
Check Engine: Electronic Traction Support? djck5 W210 E-Class 7 09-20-2006 12:41 AM
EL. TRACTION SUPPORT what the F#@K! Sandro N W210 E-Class 8 11-08-2005 05:00 PM
Where exactly is the AUX output in a 04' G500? I've searched and searched the forums Man-Du-Ru-Gas G-Class 11 12-28-2004 07:15 AM
What removes water or soap stains on glass? I've tried a bunch of stuff but no luck... SteveL R170 SLK Class 22 09-09-2003 12:04 PM
