Old 09-19-2006, 11:39 PM   #1 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
differential leak or overflow from breather
I noticed the top side of the differential case has a thin layer of oil residue. The surface was moist. It was not soaked and there was no obvious drips forming. I wiped it clean, so far after maybe 3k miles and did not notice any new oil stains.
Is it possible that it overflowed and came out of a breather? (Is there a breather?)
The car has 35K miles and never had any differential work done.
I've heard other people had similar problem. Is it a leak? Is it a problem?
How long does manufacture warranty covers the differential?
Thanks.
cerritos is offline   Reply With Quote
Old 09-20-2006, 12:45 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Thanks.
Call your dealer.
JOE55 is offline   Reply With Quote
rear differential leak? djblu R129 SL Class 8 01-01-2006 03:30 AM
Fuel overflow basix W126 S,SE,SEC,SEL,SD,SDL Class 1 12-25-2005 10:05 PM
Overflow mechanism on transmission bell housing? ninjamonkey W140 S-Class 0 07-28-2004 03:08 AM
gasoline overflow Southin W126 S,SE,SEC,SEL,SD,SDL Class 7 08-03-2003 02:52 PM
Gas coming out of the overflow heffror W124 E,CE,D,TD Class 3 03-22-2003 10:44 AM
