» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 10-19-2006, 04:55 PM   #11 (permalink)
netdvn's Avatar
Date registered: Oct 2005
Vehicle: E-Class, SLK
With my eyes are widely open to see through the fish tank but I'm not able to suck all of the water out from the tank ... what does it make you feel confidence that the sucking technique will do better than the draining’s?
Take it easy!
Netdvn
netdvn is offline   Reply With Quote
Old 10-19-2006, 05:21 PM   #12 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
What, you remove the drain plug from your aquarium?
Seriousely, some cars today are designed to have the oil sucked out the top. It doesn't have to work better than draining, since you will never get all the oil out either way. Just change it often enough, and you'll be fine with either method.
Old 12-14-2007, 03:49 PM   #13 (permalink)
rostam's Avatar
Date registered: Oct 2007
Vehicle: 97 E420
Just finished by oil change and...
what a royal pain in the ass
Clearly the engineers at Mercedes were smoking crack. Is it really necessary to disassemble and remove the air intake to access the oil filter, which spills all over the place when you remove it.
I am disliking this car more and more....
W210 E420
rostam is offline   Reply With Quote
Old 12-14-2007, 06:50 PM   #14 (permalink)
ohlord's Avatar
Vehicle: 1999E320 Wagon,2000 E 320 Wagon, 2000 E 55 powered wagon MGB Track/Rally 94 Subaru
you remove
the filter after you have drained a few liters of oil out and then it's not so messy.
Old 12-14-2007, 08:39 PM   #15 (permalink)
Marinel's Avatar
Date registered: Sep 2007
Vehicle: 1997 E320
When you guys change your oil filter do you place the filter inside the cartridge or do you snap it onto the lid and then put it back on? Also could somebody clarify to me what a fleece filter is?
Marinel is offline   Reply With Quote
Old 12-14-2007, 10:09 PM   #16 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/ML320/Audi A4 quatro
Fleece is different filtering material, than most common paper. At this point it is superior on gassers. The cartridge goes on the filter shaft before inserting into the housing.
I sucked the oil on ML55 and then pulled the plug. The bottom drain dropped 2 tablespoons of oil, but after reinserting the plug, I was still able to gargle some oil via dipstick tube (no tubing inserted). Bottom line, even if you drop the pan and wipe it clean, you'll always have few oz of oil resting on the engine shelf, cooler and tubings. Nothing to sweat about.
BTW right now Kragen (Checker) is having $1 off on Mobil 1 bringing 0-40 price to $5.
Kajtek1 is offline   Reply With Quote
Old 12-15-2007, 03:15 AM   #17 (permalink)
ohlord's Avatar
Fleece
filter is spec for the fss engines 99 and up that require mb spec synthetic oil for 10k oil changes,no need for you to worry on the m104 6 banger,you are before their time
Old 12-15-2007, 12:20 PM   #18 (permalink)
sailswish's Avatar
Vehicle: 2002 E320 Silver Wagon
Just finished my first Benz oil change. What a joy and super clean with that oil filter on top. Yes, I sucked. What a hassle my old Volvo 740 was with a side mounted filter buried deep within the engine with all the oil gushing out as it was unscrewed.
sailswish is offline   Reply With Quote
Old 03-09-2008, 08:21 PM   #19 (permalink)
Date registered: Nov 2007
Did any one know what is the exact or range quantity of the engine oil on 93 CLK500?.
Ben
badinata is offline   Reply With Quote
Old 03-09-2008, 08:33 PM   #20 (permalink)
ohlord's Avatar
Any
conventional oil that meets specs for before MY98
Mercedes-Benz Engine Oil Recommendations
your manual should indicate also.
How to DIY oil change on your C230 spoons W203 C-Class 80 10-07-2009 08:40 AM
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 03:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 08:58 PM
DIY oil change Neb W202 C-Class 28 06-12-2008 06:18 PM
Need DIY guides for 97 E420 ATF, differential & coolant change ProV1x W210 E-Class 2 10-01-2006 08:34 PM
