Old 09-10-2006, 10:32 AM   #1 (permalink)
netdvn's Avatar
Date registered: Oct 2005
Vehicle: E-Class, SLK
What Are These Tools For?
These tools came with the MB tool kits. I hope I will never use them but wonder to know what they are for. Thx,
Take it easy!
Netdvn
netdvn is offline   Reply With Quote
Old 09-10-2006, 10:52 AM   #2 (permalink)
Date registered: Apr 2006
Vehicle: 00CLK320 (mine) 00E320 (wife) was 94 & 95 C280 (sold both).
The top tool is the tow hook.
The lower one is for the wheel's bolt align (where is the bolt to be in, when you mount the wheel back).
I believe there are some instructions in the manual show you how to use them. Regards.
00CLK208 is offline   Reply With Quote
Old 09-10-2006, 12:21 PM   #3 (permalink)
netdvn's Avatar
Thanks 00CLK208. I bet several Benz owners, including me did not know there is a special alignment bolt tool that helps to remove and install the wheels. Sorry MB, I used to get angry at the Benz's designer when removing and installing the wheels on my E320.
Old 09-11-2006, 06:42 AM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
" I bet several Benz owners, including me did not know there is a special alignment bolt tool that helps to remove and install the wheels."
only the ones who don't read the manual.
It does make life a bit easier when trying to align the lug bolt holes. Hopefully you'll never need the tow bolt.
Len
sokoloff is offline   Reply With Quote
Old 09-11-2006, 09:13 AM   #5 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Originally Posted by sokoloff
" Hopefully you'll never need the tow bolt.
Len
WHAT?
You are not using your car for pulling tree stumps?
Kajtek1 is online now   Reply With Quote
Old 09-11-2006, 10:11 AM   #6 (permalink)
netdvn's Avatar
Originally Posted by Kajtek1
WHAT?
If I knew it last week, I would use it to pull a couple trees that were leaned on my neighbor back yard from the wind of Ernesto.
Old 09-11-2006, 01:10 PM   #7 (permalink)
Date registered: Aug 2006
Vehicle: Mercedes Benz E-230 P reg 1997
MB's like women once you break the cover to tow it .. they wont be put on correctly again
anmar75 is offline   Reply With Quote
Old 09-11-2006, 01:19 PM   #8 (permalink)
netdvn's Avatar
... not my woman .
Old 09-11-2006, 02:52 PM   #9 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Len
Len's right, but a word of caution for the alignment tool. It's only aluminum and it's meant specifically to align the wheel, so you have to be careful when you install the wheel over it that you don't put any of the wheel's weight on it or it will bend -- or worse, shear off in the hole. Personally I never use the darn thing; the wheels are hub-centric, so once you get them in place the hub supports them and it's usually pretty easy to rotate the wheel to the correct alignment. Now, parked on the side of the road at night in a rainstorm when your flashlight batteries are weak, then I'd probably use the tool, but otherwise...
Take care and enjoy the ride,
Greg
Old 09-13-2006, 05:47 PM   #10 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
Originally Posted by gregs210
........Now, parked on the side of the road at night in a rainstorm when your flashlight batteries are weak, then I'd probably use the tool, but otherwise...
Greg
LOL!! Reminds me of what happened to me a few years back with my black W210 in london.
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
auto tools marbendill G-Class 11 03-22-2006 10:30 AM
OM352 Tools Mogly406 Unimog 0 03-15-2006 07:51 PM
Specialty Tools??? andrew6981 W126 S,SE,SEC,SEL,SD,SDL Class 7 07-16-2004 09:50 AM
G tools yamraptor G-Class 5 02-03-2004 10:16 AM
w203 tools Guest (MBNZ) W203 C-Class 5 12-23-2001 10:51 PM
