Old 09-09-2006, 10:58 AM   #1 (permalink)
Date registered: Jun 2006
Vehicle: 1998 e300turbo diesel/1996 bmw z3 garage queen
1998e300 turbo diesel wont start
I tried to start it this morning turned over but wouldnt fire .I added 4 gallons of diesel and still no go.Any ideas would be appreciated.Thank you
voilodion is offline   Reply With Quote
Old 09-09-2006, 11:09 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
If you run out of fuel, you need to prime the system after filling up. Cranking for long time with gas pedal on the floor might work, but than you might need new starter or battery.
Read the manual. There is bleeding screw on the top of upper filter and loosening fitting on the injector helps. Do you have manual priming pump on your engine?
Kajtek1 is online now   Reply With Quote
Old 09-10-2006, 07:26 AM   #3 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
That engine is self priming, but it can take awhile. Sounds very much like a leaking O ring in the fuel system is allowing air in. Do you see any bubbles or leaks in the plastic fuel lines? Did you recently replace the prefilter and not also replace the O ring?
Len
sokoloff is offline   Reply With Quote
Turbo Charging A 300 E With Turbo Diesel Parts Sean300 W124 E,CE,D,TD Class 22 12-05-2006 11:18 PM
Start, ran, wont start again horsessmellfunny W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 09:58 PM
MB 250 C Turbo diesel doesnt start. los1950 W202 C-Class 0 12-11-2005 11:40 AM
Instaling a Turbo and intercooler on a non Turbo 602 diesel engine scapollo G-Class 0 10-19-2004 12:24 PM
82 300sd turbo diesel been stored won't start- Help! davis3186 W126 S,SE,SEC,SEL,SD,SDL Class 8 04-19-2004 10:32 PM
