Old 07-03-2007, 03:15 PM   #11 (permalink)
Date registered: Dec 2006
Ohms Law ..
If you wire the speakers in series the resistance is R1+R2=Rt
R1 is the resistance of the first speaker, R2 is the resistance of the second and Rt is the total resistance ...
Most car speakers are 4 ohms so in this case in series it would be 4 + 4 = 8 ohms
V=IR (voltage=power x resistance) - this is ohms law ... V is constant in the is case so if R goes up I goes down ... this means if you hook 2 speakers in series you will get LESS current (amps) to each and thus for the same amount of power from the amp it will be a touch quiter (just like the post above says)
now in parallel ...
1/R1 + 1/R2 = 1/Rt (one over R1 + 1 over R2 = 1 over Rt)
or for a 4 ohm speaker
1/4 + 1/4 = 2/4 = 1/2 = 1/Rt so Rt = 2 ohms
What does this mean? Looking at ohms law
V constant
R went down from 4 ohms to 2
so the Current I will go UP ... CAREFUL!!! is this amp stable at 2 ohms ... you could fry your amp if it's not ... it sounds like some people have done this but if you do, do it at your own risk ...
durado is offline   Reply With Quote
Old 07-03-2007, 05:27 PM   #12 (permalink)
OceanView's Avatar
Date registered: Sep 2004
Vehicle: 96' W210 & 07' W211
now in parallel ...
V constant
Exactly!
Good explanation.
OceanView is offline   Reply With Quote
Old 07-04-2007, 04:01 PM   #13 (permalink)
Date registered: Jun 2007
Vehicle: 1997 E320
I'm about to do a full system change! What I wanted to know is, do you just lift the rear grills up or does the whole back deck come off and how (rear speakers)?
Down South is offline   Reply With Quote
Old 07-04-2007, 04:15 PM   #14 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
I was considering bridging components, any advice. If I did purshase two extra
6" woofers for the back, I would consider components and then bridge with stock left/left right/right. Any thoughts on this method?
slybydesignw210 is offline   Reply With Quote
Old 07-05-2007, 11:04 AM   #15 (permalink)
OceanView's Avatar
It would work ONLY IF you had an amp cable of being bridged.
I don't think the stock radio could do that.
Old 07-05-2007, 11:29 AM   #16 (permalink)
Oh ok, I see what your saying, the amp cable will run better sound through the bridge set up?
Isnt that the Big Blue Cable?
Old 07-06-2007, 07:19 AM   #17 (permalink)
Vehicle: 1997 E320
How do you access (get to) those rear speakers?
Old 07-06-2007, 10:17 AM   #18 (permalink)
From the trunk. Look upwards and you will see it.
Old 07-06-2007, 10:58 AM   #19 (permalink)
OceanView's Avatar
I don't have a stock stereo system so I don't know what colors any of the existing cables are.
Bridgeable amps are used to increase the output of the amp.
Not all amps can do this.
Do not try bridging your amp unless you know for sure it can handle the lower impedance otherwise it will get fried.
Old 07-06-2007, 12:53 PM   #20 (permalink)
Thank you
Anyone have an extra stock grille for cheap? jtbeche W208 CLK Class 3 02-10-2006 09:29 AM
Wiring amp to stock deck DA_SURG Audio & Telematics Forum 7 08-18-2005 10:48 AM
Replace the Rear Woofers on a 99 Clk 230 Vincenzokr Audio & Telematics Forum 0 01-25-2005 05:45 AM
any one please have a stock dash board extra for sale lorinser408 W202 C-Class 1 09-17-2003 01:22 PM
any way i can fit a MD deck under my stock CLK stero ? the stero guy told me if i put a MD deck .... Guest (MBNZ) Audio & Telematics Forum 0 02-01-2002 06:17 PM
