» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 09-05-2006, 10:54 AM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
DIY Brakes, with pictures...
Hey, everyone.
One benefit of the new format is I can now attach a PDF.
Some to most of the DIY is applicable to other MBZ models.
Mr. Mods, can you add the link for this thread to the sticky list of DIY procedures?
Take care and enjoy the ride!
Greg
Old 09-05-2006, 12:11 PM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
greg
JOE55 is offline   Reply With Quote
Old 09-05-2006, 12:17 PM   #3 (permalink)
OBX884's Avatar
Date registered: Sep 2002
Vehicle: '86 560SEC, 87 560SL
Great instructions... I just added them to the DIY sticky
'86 560SEC & '87 560 SL (also in the family - '97 E420 & '01 E320 4MATIC Wagon)
OBX884 is offline   Reply With Quote
Old 09-05-2006, 02:22 PM   #4 (permalink)
gregs210's Avatar
Thanks, OBX. You missed changing the "last updated" part on the subject line, though.
How's the E? Anything new on the water-skiing considerations?
Old 09-06-2006, 05:24 AM   #5 (permalink)
jka
Date registered: Aug 2006
Great job! This is really useful stuff!
jka is offline   Reply With Quote
Old 09-06-2006, 08:47 AM   #6 (permalink)
OBX884's Avatar
Well a few days in the sun got rid of the wet dog smell... so back to normal for a bit now...
Old 02-24-2007, 04:01 PM   #7 (permalink)
Vehicle: IRL '00 E320 - Sold! US '98 S420 Silver
Thanks Greg,
Used this today and I am now the proud owner two new shiny brake discs and a new set of front brake pads!
micosavo is offline   Reply With Quote
Old 02-24-2007, 05:33 PM   #8 (permalink)
Vehicle: 2001 E320 2WD
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
Gregs,
Thanks again for the DYI on brake pad. I can sure use your information. Let me express my appreciation again!
Raylee177 is offline   Reply With Quote
Old 02-27-2007, 09:07 AM   #9 (permalink)
Date registered: Feb 2007
Vehicle: 1999 E320
I purchased a 1999 E320 with 44M miles on it. It now has 70M and the break liner wear warning has gone off. I have changed pads in both American and foreign cars before, so I am not new to this. However, my previous cars were not MBs, so I would prefer not to expand the problem.
I am looking for direction on the following:
1. I am going to change the front pads and sensors. Any input on ceramic pads versus OE would be appreciated.
2. I have felt one front rotor and it is still smooth. Assuming the other is in the same condition, I do not intend on changing the rotors.
3. I would like to flush the brake lines and change fluid. I have not bled brake lines before, so my concerns may be academic. From what I have found on the internet, it says the car should be level, starting with the line farthest from the MC. In order to do this, it seems the car would need to be lifted and placed on 4 floor stands to keep it level. The Motive bleeder looks to be a good tool for this job. So, now I need to weigh the cost of having a shop do it versus my doing it with the cost of required tools (floor jacks, bleeder, and any other item that may be necessary). Any recommendation on this would be appreciated.
4. I would like to change interior filters as well. Removal of the glove box looks simple enough. Any recommendations or words of caution are welcome.
5. Lastly, it appears that some parts are special order, so I may as well order everything through the internet. If someone has a recommendation on which supplier would be best to use, I would appreciate it.
Thanks.
eksantos is offline   Reply With Quote
Old 02-27-2007, 04:42 PM   #10 (permalink)
gregs210's Avatar
Thanks.
Hi, EK.
Congrats on the purchase and lots of apparently trouble-free miles.
Although you didn't ask, if you haven't already done so I'm going to suggest that you get your ATF fluid and filter changed as soon as possible.
And with no further ado...
If you are satisfied with the braking performance then there is no reason to install other than OEM pads. Ceramic pads will wear rotors faster than stock, but you have less brake dust. After lots of reading, etc. I decided on the Axxis Deluxe Plus pads. Barely more expensive than stock, slightly better performance, and much reduced brake dust. Re: Rotors, smoothness is only one small part of replacement. Exceeeding minimum thickness (through wear or turning) and warping are the two most common reasons for rotor replacement. To be sure, buy a micrometer and measure a few points on the rotor, the minimum thickness spec is stamped in the perimeter of the rotor. Better to be safe than sorry, rotors are cheap enough.
If you read through the DIY you'll see there are no ugly surprises waiting to bite you, but I'd tend to agree with you that you're not going to get everything in one visit to a local store, unless it's one that specializes in German marques, and you'll pay for that convenience. Typically such outfits are staffed by like-minded enthusiasts, so their knowledge, pointers and assistance may be worth the premium just to keep them in business. Otherwise you're going to the dealer or on-line.
That said, the place I most often order OEM/equivalent for my car is Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips. Free shipping at the $50 price point and fast service. Mercedes Parts, Mercedes Benz Parts is a sponsor and mod on the site and I've also used Auto Parts Warehouse | Discount Auto Parts - Get Free Shipping - Auto Accessories - AutoParts - Performance Parts.
I've not bled my car's brakes, I had the indy do it when I otherwise took it in as the upcharge wasn't too bad and it was a complete flush, not just bleeding them. A pressure flush is different from bleeding in any event. From my perspective, considering the cost of the fluid, what to do with the old stuff, the mess to be made and the value of my time -- and the unlikely completeness of the flush -- it just wasn't worth it to me. That said, if the stuff you read on the internet was generic I'm not sure how applicable it would be to your MBZ; the last car I did with ABS all you did was crack the screw, attach the hose and pump the pedal slowly, in the end the ABS pump does the work and didn't suck in air. Perhaps some of the other site gurus would have more guidance for you here.
If you use that all-important-and-handy search function you'll find a few posts on this. I keep meaning to do mine, should I ever get around to it I'll take a couple of pics. From my understanding the only tough one is the charcoal beasty (and that moreso in the context of paying for it...)
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
2000 S430 Brakes and Motor mounts DIY? jobambo W220 S-Class 2 08-08-2006 10:55 PM
My DIY Euro Bi-Xenon Pictures!!! Vik W163 M-Class 17 09-26-2005 03:15 PM
ml430 brakes diy--er doyle613 W163 M-Class 3 09-18-2004 03:35 PM
DIY Brakes Chuck V W203 C-Class 1 07-30-2004 01:43 PM
Is replacing brakes on a ML320 a DIY job? bavenda W163 M-Class 4 09-19-2002 06:56 PM
