You received some great responses on the brake job. I don't think I can add anything to the already posted items. Make sure you do replace the wear sensors - they are cheap
Thank you Greg, I just did my brakes! I did my 1970 Beetle and that was the proving ground for the "Big Girl". Saved me several hundred dollars. Thanks so much for the guide!
Everything should be made as simple as possible, but not one bit simpler.
Albert Einstein
I have changed dozens of brakes and was fearing my E320 would be over-complex. It appears rather standard----this PDF is great, thanks for your effort.
Awesome!!!!!!!!
I’m changing brakes this weekend..............Very helpful, Thanks
Hey, gatonls, I knew you'd find us.
Take care and enjoy (stopping) the ride,
Greg
I think you mean that for the front calipers bracket mounting bolts, they are 17mm, not 7.
Glad you got it all taken care of.
No, I did mean the caliper mounting bolts. The caliper mounting bracket on my car is secured with 18mm bolts. The caliper itself is retained by two sliding bolts that have a recessed 7mm hex head. MB must have updated the design in later chassis with the Torx heads? Too many stripped hex ones??
I use the Mintex pads from autohausaz for my wagon and coupe (same front, slightly different rear caliper). Total cost is about $80 for pads, "anti-squeak" paste, and sensors for all four wheels. They don't have the hole for the sensor, but they do have the slot to hold the sensor. I just drill the hole for the sensor and it works fine.
