Old 08-23-2006, 12:20 PM   #1 (permalink)
DominicArnold's Avatar
Date registered: Apr 2006
Vehicle: 1999 Mercedes E 320
Gas Guage stops at 3/4 full
I fill my car up until pumps stops but gas guage only shows 3/4. Do you think if I try to overfilling the tank might solve the problem? Possible by overfilling might free stuck gas guage?
Thanks
Dominic
DominicArnold is offline   Reply With Quote
Old 08-23-2006, 12:42 PM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
That will NOT fix the problem..Its the Fuel level sending unit..its a KNOWN PROBLEM..
Easy to replace..make sure that you have less than 1/2 of a tank to avoid leaks
Mercedes made a Updated Fuel Level sending Unit to correct the problem
Mark Cummins is offline   Reply With Quote
Old 08-23-2006, 02:31 PM   #3 (permalink)
netdvn's Avatar
Date registered: Oct 2005
Vehicle: E-Class, SLK
Smile
Thanks
Dominic
It happened to my car about more than a year ago for several months then suddenly the problem went away. During that time I topped off a little bit when filling up the tank and reseting the trip odometer to make sure to refill the tank again after every 300 miles. It was hard to know how much the gas left in the tank with a dead gas gauge. I'm still not sure if the top-off thing helped or I was just another lucky guy.
Take it easy!
Netdvn
netdvn is offline   Reply With Quote
Old 08-24-2006, 10:53 PM   #4 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Know problem with the MB fuel sending units in the tank. I got mine replaced for free from the dealership. MB even had a class action suit against fuel companies for some of the additives ruining the fuel sending units. VW / Audi and BMW claimed the same thing. See if the dealership will fix it for you. They did mine with no question.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 08-25-2006, 10:06 PM   #5 (permalink)
How long ago and where did you get yours fixed? I have a 99 E320 and usually go to MB dealer in Scottsdale.
Thanks
Dominic
Old 08-26-2006, 06:32 PM   #6 (permalink)
E-Klasse's Avatar
Hi Dominic
I go to MB of Chandler. I got mine replaced last year in my SLK320.
Old 10-18-2007, 01:39 PM   #7 (permalink)
Date registered: Jun 2007
Vehicle: 2000 E430 4Matic
Bringing this back up.............
Does this go for E-Class cars also?
I top mine off and it shows 3/4.
Only thing is that when I pull up the dash info after filling it, it shows 17 gallons. Does that have to do with the bad gauge reading too?
Where is the gauge located and is it a bad gauge or bad float?
jh225 is offline   Reply With Quote
Old 10-18-2007, 01:54 PM   #8 (permalink)
Vehicle: ML500, E320 4Matic
Had the same problem with the 01 E that I had. Yes, the dash readout will be affected also as its the same sending unit. As stated earlier in this thread its an easy fix and the new sending unit is updated and improved (Unless you buy one from E bay or another questionable source). Its not a big deal to replace.
sosh is offline   Reply With Quote
Old 10-18-2007, 02:18 PM   #9 (permalink)
Yeah, now the only problem is that the new sending unit is going for $170
Damn that's a lot of coin for a stupid float with a sender.
Old 10-18-2007, 02:59 PM   #10 (permalink)
Ryanoscerous's Avatar
Vehicle: 2001 E430 4matic
This worked for me...
http://www.benzworld.org/forums/w210...l+sending+unit
Just needed a little fiddling, no need to replace it.
Everything should be made as simple as possible, but not one bit simpler.
Albert Einstein
Ryanoscerous is offline   Reply With Quote
Full tank of gas, but slowly (over approx 30 min) will drop to empty, but tank full HACK THT W163 M-Class 6 06-22-2006 09:56 AM
Fuel guage reading 3/4 full when full up..... Slk230UK99 R170 SLK Class 8 01-24-2006 06:25 AM
petrol guage sticks on full blue-boat W123 E,CE,D,CD,TD,TE Class 6 10-29-2005 09:59 AM
Engine stops when the foot is off the gas pedal irshadwahab General Mercedes-Benz 6 11-30-2004 10:29 PM
Gas Gauge reads 7/8 Full with a Full Gas Tank Shawn5454 W140 S-Class 5 06-13-2004 05:36 PM
