Here is one for the Benz guru's, M119 engine experts, etc.
I have been using a blue TOPSIDER oil removal pump on my 97 E420 for nearly a year. The whole process- removing oil from the dipstick opening is superior in my opinion- Here is one oddity I noticed.
http://www.evozine.com/benz/oil.ext2.jpg
-Using the topsider on my car I've noticed that it only removes a portion of the oil.
-Today after removing as much oil as could be extracted via the pump I went ahead and removed the oil plug on the oil pan. To my suprise I drained out 1 .25 quarts of oil from the bottom.
My neighbor has a early 90's 500E. When he uses the Topsider nearly all of the oil is removed. His oil pan does have a different shape; however the large amount of oil left in my pan after the Topsider extraction is odd..,
