Old 08-20-2006, 07:38 PM   #1 (permalink)
Date registered: Aug 2006
Exclamation E300 won't start (immobilizer kicks in)
Hi all,
Nice forum.. Hopefully someone has some tips for me.
I've got a '96 e300 I recently bought used that worked great until the other day. I attempted starting the car and it would not start but was turning over fine. I realized the rear view mirror green/red lights were flashing off and on. From what I can tell the immobilizer has kicked in for some unknown reason. The first time I was able to "reset" something by disconnecting the negative terminal to my battery and the car subsequently started normal, no immobilizer problems. Then a week later the same problem. Again, I disconnected the negative battery terminal and it worked... All of these times nothing abnormal was done after shutting off the car, locking it as normal either with the key at the door or the infrared remote. Also no obvious errors are reported in the dash that I see. Also using the infrared to lock/unlock the car still works fine but does not clear this error.
The car has sat for a week, I come home and try to start with the same problem. However, this time the battery trick is not working. I'm about ready to roll the car off a cliff.
Any tips of things to try or should I just take it to the dealer? I am correct in understanding the immobilizer has been engaged? The car seems to have been very well maintained otherwise..
Thanks,
-Jason
jbirdfunk is offline   Reply With Quote
Old 08-21-2006, 11:51 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Do you have the owners manual with the car? You may ned to resync the remote with the computer to clear the flashing lights on the rear view mirror. That happens if the battery is changed in the remote key fob. Other wise the security system is messed up so your fuel pump relay is not working. You can lock and unlock the doors with the remote? I would do the resync first to see if the light stop flashing after you replace the battery in the keyfob.
I have heard of problems with the 97 with the big ring extending out from the ignition switch. It is a coil that reads to chip in the key fob. If the keyfob is bad, it will not let you start the car.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 08-22-2006, 11:36 AM   #3 (permalink)
Thanks for the reply. Yes the key fob remote locks and unlocks the car without problems. Does this mean I still need to re-sync?
I'll buy new batteries and see if that helps.
Old 08-27-2006, 04:52 AM   #4 (permalink)
Vehicle: Mercedes Benz E-230 P reg 1997
i am having almost the same problem apart from my door doesnt open manual for a physical reason
anmar75 is offline   Reply With Quote
Old 08-30-2006, 06:13 AM   #5 (permalink)
Electrical issue
I have an almost identical(but intermittant ) problem. Two tows and ten days at a MB dealership and I am non the wiser. They have replaced a unit that receives the fob signal and sends it to the computer (called an FZsomething)
I am hoping this will fix the problem.
computer was sent away for testing and came up OK. All electrical lines were checked.
I am very keen to hear about your progress
Regards
KO
Ken Owen is offline   Reply With Quote
Old 08-31-2006, 12:24 PM   #6 (permalink)
its the mirror kit what you need to replace
thats what the AA man told me ...
the red light on the mirror if its stops working you will nead to change the mirror cost new £110 + VAT from MB i will explain the fitting when i do it in pictures
Old 09-08-2006, 11:35 PM   #7 (permalink)
No go with new batteries
OK so I replaced the key fob batteries with new energizers. Seemed to work for a while but of course the problem came back.
One thing about this car is I rarely drive it.. and tonight I tried the car and it would start fine, but earlier today at 5pm or so it would not start even after repeated trying to resync the key.. It would lock/unlock the car fine with the remote..
From what I remember it FREQUENTLY has this problem around that time of day. Cars parked in my driveway point due west, right at the sun. Is it possible the optical eye on the visor is getting whacked out due to sun rays and hosing my ride? Am I crazy? I hate this problem and want to unload this car!
Old 09-09-2006, 05:02 AM   #8 (permalink)
it happens to me as well when there is some sun in london .. as we have only rain all the year .. but my problem is i cant open the door manually coz the door lock is stuck some how ..
Old 08-26-2007, 03:37 PM   #9 (permalink)
Date registered: Jun 2006
Engine immobilizer kicks in
I have exactly the same problem on my '96 E300D. A local mechanic tried to fix it by replacing the car's battery as well as the battery in the keyfob. It seemed to work for only a week or so, then the same problem came back.
I am now thinking of installing a retrofitting keyless entry system to bypass the factory alarm system.
Does anybody have experience?
Thanks.
izuyan is offline   Reply With Quote
Old 08-26-2007, 04:58 PM   #10 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Check the K40 relay module. There are a number of threads on that piece.
Attempting to retrofit a keyless entry system will not solve this problem.
Help with 99 E300 DT won't start Guest W210 E-Class 4 01-31-2006 12:40 PM
bought 1999 S reg s/a a class cant find immobilizer port 2 put my immobilizer key in Ali_c W168 A-Class 2 08-28-2005 01:01 PM
Immobilizer spit64 W124 E,CE,D,TD Class 1 07-30-2005 12:04 PM
Immobilizer Cmdr737 R129 SL Class 3 04-11-2005 11:53 AM
remote start for E300 or E320 Avezbakiyev W210 E-Class 3 12-11-2004 10:35 PM
