Old 08-20-2006, 12:45 PM   #1 (permalink)
JP1
Date registered: Nov 2005
Vehicle: 2002 E320
Driver door latch adjustment
On my 02 E320 the drivers door is harder to close than all the other doors, it requires a good almost slam with some oomph behind it to close completely. Every time I try to just swing it closed it only catches on the first latch. Also when I open it, it really pops when the catch releases, like there's a lot of pressure there. The other three doors all close with a normal light swing and open nicely.
I loosened the catch to try to adjust it a little but it doesn't seem like it's adjustable. I can't see any way to adjust this. There are no obvious pressure spots or alignment issues showing, The car has never been tweaked, but this door annoys me every time I have to make two or three attempts to close it.
Any ideas on how to fix this?
JP1 is offline   Reply With Quote
Old 08-20-2006, 01:46 PM   #2 (permalink)
OBX884's Avatar
Date registered: Sep 2002
Vehicle: 01 E320 4MATIC Wagon
I was having the opposite problem-- My door wouldn't latch tightly enough and the interior lights kept coming on when I took hard right-hand turns. To adjust the latchplate which does look like it's not adjustable, my mechanic loosened the screws on the plate and gave it a good whack with a heavy rubber mallet and then retightened the screws. Problem solved...
'86 560SEC ('97 E420 & '01 E320 4MATIC Wagon)
OBX884 is offline   Reply With Quote
door latch 300sdl 126 lost screw ? deadheadman General Mercedes-Benz 0 04-18-2006 10:10 AM
is there an actual MB door latch rattle fix yet? da_nailgun R171 SLK Class 3 11-03-2005 01:52 AM
Messed up door latch Va170_Bill R170 SLK Class 7 10-17-2005 07:58 AM
Door handle Latch Problems? phal W126 S,SE,SEC,SEL,SD,SDL Class 2 05-12-2005 07:21 PM
door latch removal GDJ W126 S,SE,SEC,SEL,SD,SDL Class 0 03-04-2003 07:32 PM
