Old 08-12-2006, 11:40 PM   #1 (permalink)
Date registered: Aug 2006
E 320 1998 Climate control problems;
E 320 1998 Climate control problems; I hope someone can help me with this. From the center vents (which is divided into two vents the passenger and driver controlled) I get cold air (air conditioned) from one side and warm air (not hot) from the other. The side vents and the bottom vents seem to have a different system. Adjustment to temp displayed on either passenger or driver side does not change the air temp coming from the middle. However if "Hi" is selected, the side and the bottom vents will respond and blow hot air; otherwise there is no change. "ECO" will shut the air conditioner off. In addition, all up/down valves respond to commands from the controller. I have checked the duo valve and the motor that runs the hot water through the valve. I have checked the vacuum controller under the clove-box, the pneumatic valves that control the air flow to the top or bottom, inside/outside air, filtered air, and all of the fuses. They all appear to work properly. I am at a dead end. I surely appreciate any suggestions regarding this nightmarish system.
Thanks
John
E-mail (artistwyou@yahoo.com)
artist is offline   Reply With Quote
Old 08-13-2006, 04:50 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Cold air on the passenger side and warmish air on the driver's side normally indicates a low charge.
Len
sokoloff is offline   Reply With Quote
Climate Control Problems 190E_goon W201 190E, D-Class 3 12-26-2006 09:33 AM
Climate Control Problems MMBENZ W140 S-Class 4 06-11-2006 04:50 PM
Climate Control Problems wmka89 W126 S,SE,SEC,SEL,SD,SDL Class 9 02-25-2005 09:02 AM
Climate control problems tnt W124 E,CE,D,TD Class 0 01-06-2005 01:16 PM
Climate Control Problems. noctum W126 S,SE,SEC,SEL,SD,SDL Class 5 04-04-2004 02:17 PM
