I decided to write up a little step by step manual to help whoever replaces their factory headlamps with the Depo clear replacements. They come with extremely limited and confusing instructions - so for the ultra beginer (like myself) here is how it goes:
I have a 96 E320.
1. Go here to watch the video on how to remove the bumper plate holding the headlamps in place on your vehicle. There are 2 screws to take out, one directly on top of the plate and one becomes visible when you remove the black rubber towards the grill of the vehicle.
http://mb.braingears.com/W210/w210/media/W210%20J.mpg
2. Once you have the plate loose, gently pull it towards the middle of the car and dont remove the rubber attached - just let the plate hang.
2. Now take out the other 3 screws. One is at the top right of the headlight assembly, the second is underneath the healight assembly parallel to the bumper and facing out, and the third is underneath the little light of the 2 lights.
3. Now gently remove the headlamp assembly. There will be 2 things hooked up to it, one is a 4 prong electrical hookup and the other is a 2 prong. Your headlamp assembly is now free.
4. Your depo headlamps are shipped without bulbs. I went out and bought 4 Sylvania Silverstar H7 bulbs. You do not need the w5w bulbs as mentioned in other threads as the depo headlamps are now shipped with these bulbs already in place.
5. The depo headlamp is shipped with a strange "spring" (really 2 silver rods) assembly that needs to be removed. You would never know this because there are no instructions. You cant miss them, they look out of place and one of them actually stratles the plastic casing while the other goes down to the big headlamp assembly. Remove both rods and discard.
6. Install the 4 new bulbs (2 in each headlamp assembly). You can take off the plastic backing on the old factory headlamp assembly to see how to do this. You basically put the bulb in place, fasten down the 2 wire clamps, and then attach the wire housing directly to the back of the lightbulb.
7. Now you need to go to the top of your depo assembly and remove the blinker light - its the black circle with 2 silver prongs - by twisting it out. Now go to your factory headlamp and do the same. Take out the bulb out of the factory blinker and put it in the depo - and screw the blinker assembly back in to the depo headlamp.
8. You should now have (in each depo) 2 new H7's, one blinker bulb, and the w5w that already came from depo already installed.
9. Now go back to your vehicle and wiggle the depo assembly in, hooking up the 2 electrical jacks to the new assembly. TEST YOUR LIGHTS NOW TO SEE THAT LOW BEAM HIGH BEAM AND BLINKERS ALL WORK.
10. Put the 3 screws back in that hold the assembly to the frame of the vehicle.
11. Put the plate cover back in place and screw back in the 2 screws that hold it in place.
ALL DONE!!
I am an absolute newbie and I would say this took me about 2 hours. A pro could do this in a half hour tops.
GOOD LUCK!!
