Old 08-11-2006, 09:44 PM   #1 (permalink)
Date registered: Jul 2006
Vehicle: 98 MB E320
BASS ASR light
I bought new tail lights of the newer style for my 1998 E320. They look really nice on it. The only problem was that the break light bulbs were not fitting in correctly. All of the other light bulbs had fit in fine. Since they were not in correctly, the lamp defective light was on and they didn't go on when you pushed the breaks.
I then had a friend go inside the car while the car was on and tap the breaks. As he tapped the breaks I fixed the right light by wiggling it around until i got it into the right place. Then I went over to the left tail light and started to do it and all of the break lights went off. Now, no matter what we do, none of the break lights work including the center one and the BASS ASR light came on. Was that because I was messing with the electrical while the car is on? What could be the problem?
Thanks to anyone that can help me and I would really appreciate immediate responses.
Sincerely
Nate
di_nate is offline   Reply With Quote
Old 08-12-2006, 11:31 AM   #2 (permalink)
Vehicle: 98 MB E320
Can someone at least tell me what it is?
Old 08-12-2006, 12:27 PM   #3 (permalink)
Vehicle: 98 MB E320
Actually, could it be a fuse? I cannot seem to find the fuse anywhere though if it exists. What would it be listed as in the paper? Where is it located?
Old 08-12-2006, 02:08 PM   #4 (permalink)
Vehicle: 98 MB E320
Basically I have no brake lights at all (including the high level light). I dont know if it is a fuse or what, the fuse list in the fuse box doesnt have a fuse for the brake lights, so really dont know what to do. can someone please help,
thanks
Basically quoted from another topic where they didn't get the anwer either....
Old 08-12-2006, 05:51 PM   #5 (permalink)
Vehicle: 98 MB E320
Fixed it by replacing the fuse. I thought it was going to be the break light pedal. Thanks all (sarcasm) lol
Old 08-12-2006, 06:14 PM   #6 (permalink)
Date registered: Apr 2005
Vehicle: '01 E55 AMG
the brake switch goes bad as well. but changing it is easy and costs under $30. not your problem tho.
if i remember correctly, you can slightly bend the metal contact tabs on the bulb holders for a more secure contact. die-electric grease helps too, but not too much.
45acp is offline   Reply With Quote
OK! New problem! Just fixed the asr light, today, both the asr and the abs lights has come on! Cabbe W140 S-Class 15 09-30-2006 07:10 PM
ASR Light way2fast4u W202 C-Class 6 07-13-2006 08:24 AM
sprinter ,1.2.3 gears + asr light and preglow light on. boofies W901-905 Sprinter 0 12-26-2005 03:10 PM
ASR light ( again ! ) Barabus W140 S-Class 1 01-03-2005 06:40 PM
ASR, Cruise, Low Fuel Light, Park Brake light - all failed Ameet Patel R170 SLK Class 1 03-29-2001 03:59 AM
