Old 08-11-2006, 07:40 AM   #1 (permalink)
JamieK's Avatar
Date registered: Mar 2006
Diesel fuel formula changed?
Has the diesel fuel formula changed?
I know this may be a regional thing, but does anyone know about any changes in diesel fuel lately. Our shop and independent shops are replacing the fuel lines and o-rings on later model cars like crazy. Mainly affecting 95-99 diesels. Just curious.
Jamie
But then again, I could be wrong.........
Where is everyone? Find out here (and let everyone know where you are, too)...
http://www.frappr.com/w123club
JamieK is offline   Reply With Quote
Old 08-11-2006, 10:01 AM   #2 (permalink)
Date registered: Jun 2006
Vehicle: 99 E320
As far as I know it's something that will change in the next year or so. For example, all the new Mercedes diesels will be designed to run on the new formula. Mercedes calls them their blue cars. They've changed something in it to make it considerably less of a pollutant. I can't remember what it is they've changed about it. As you're probably aware, emissions continue to get tighter all the time. This is an effort to keep diesel alive because of the fuel efficiency and power it provides.
fiatspider is offline   Reply With Quote
Old 09-07-2006, 01:09 AM   #3 (permalink)
Prez808's Avatar
Date registered: Jun 2004
Vehicle: 1984 300 TD-T
Send a message via AIM to Prez808 Send a message via Yahoo to Prez808
It rolled out on the first of this month in California. Haven't tried it out yet
***Need a replacement antenna for your w123-T? I got one for sale!***
w123: The last of the big chrome Mercedes.
Prez808 is offline   Reply With Quote
Old 09-07-2006, 07:08 AM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Leaking fuel lines and O rings is a common issue with the 210 chassis diesels. Has nothing to do with the diesel formula. Just consider it a normal maintenance item by 100,000 miles or less. If you DIY, the cost of parts is maybe $100 or so. Not sure how long the replacements will last.
Len
'99 E300TD 95,000 miles - all fuel lines and O rings replaced.
sokoloff is offline   Reply With Quote
Old 09-07-2006, 09:13 AM   #5 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
That's what I heard as well, but can't find any confirmation.
The rest of the country has like 6 more months to convert.
As far as everybody says, the low sulfur fuel doesn't require any engine changes with possibility of adding some lubricants on older engines.
O-rings and hoses replacement is recommended on older engines running on bio-diesel.
Kajtek1 is online now   Reply With Quote
Old 09-07-2006, 09:17 AM   #6 (permalink)
OBX884's Avatar
Date registered: Sep 2002
Vehicle: 01 E320 4MATIC Wagon
Here's what the 126 crowd had to say: http://www.benzworld.org/forums/w126...ur-diesel.html
'86 560SEC ('97 E420 & '01 E320 4MATIC Wagon)
OBX884 is offline   Reply With Quote
Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 12 11-10-2007 09:49 AM
Diesel fuel formula changed? JamieK W123 E,CE,D,CD,TD,TE Class 14 08-12-2006 10:31 PM
Changed fuel filter now it wont start 240D crate W123 E,CE,D,CD,TD,TE Class 10 07-29-2006 12:50 PM
Just changed my fuel filters H-TownBenzoboy W123 E,CE,D,CD,TD,TE Class 17 04-11-2006 10:18 AM
changed fuel filter but..... Oliver-Klossofv W202 C36 AMG, C43 AMG 0 09-08-2002 12:55 AM
