99 E320 Service A light reset - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-25-2006, 10:05 AM Thread Starter
DominicArnold's Avatar
Date registered: Apr 2006
Vehicle: 1999 Mercedes E 320
Can anyone direct me to any previous threads that instruct how to reset service a light (1 wrench). You would think that after spending $3K the last couple weeks at dealer they would reset light, but they said they wont unless they did the service A. even though evrything has been done.
I did a search on Benz World and didnt find anything for 99 E320.
Thanks
Dominic
DominicArnold is offline
post #2 of 13 (permalink) Old 07-25-2006, 10:48 AM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 116 Post(s)
in your owner manual. if you cant find, try searching "FSS reset" or "flexible service reset"
raymond-
47º34'N 122º18'W
raymond- is offline
post #3 of 13 (permalink) Old 07-25-2006, 11:06 AM Thread Starter
Thanks for the input; I bought car used and it didnt come with owners manual; I also searched threads and nothing on resetting 1999 E320 FSS; any other ideas?
Thanks for your help.
post #4 of 13 (permalink) Old 07-25-2006, 11:38 AM
raymond-'s Avatar
Vehicle: 99 E320
Quoted: 116 Post(s)
raymond- is offline
post #5 of 13 (permalink) Old 07-25-2006, 01:44 PM Thread Starter
Thanks for the link Raymond; the linkis for a 2001 with steering wheel controls; mine is a 99 without the same type of set-up. I will continue to search; if you happen to come across anything please let me know.
Thanks again for your help.
post #6 of 13 (permalink) Old 07-25-2006, 03:51 PM
raymond-'s Avatar
Vehicle: 99 E320
Quoted: 116 Post(s)
muh baddd.....i was rushing for work and didn't read carefully. will dig up manual when i get off work. (sorry bout that!)
raymond-
47º34'N 122º18'W
raymond- is offline
post #7 of 13 (permalink) Old 07-25-2006, 04:00 PM
raymond-'s Avatar
Vehicle: 99 E320
Quoted: 116 Post(s)
from other MB forums...
Turn on the key (door shut)
push the l/h cluster button twice to get the wrench on screen,
press and hold the button,
turn off the key for 5 seconds,
turn key back on all the while holding the button,
wait 15 seconds or so, it'll beep and reset to either 10k or 7500 depending on coding.
It should be in your owner's manual. On my 1998 E 430 the process is clearly explained on page-93.
Make sure your doors are closed.
1) Insert key into ignition and turn to position 2.
2) Within 4 seconds push button "0" button twice within 4 seconds or so to get the FSS to display and release.(this is the odometer reset button)
3) Within 10 seconds turn key to position 0.
4) Press and hold button "0" while turning the key back to position 2. Continue to hold button "0".
5) After approx 10 seconds a signal sounds and the display will show 10000 miles or 15000 km. Release the button.
Turn electronic key in steering lock to position 2.
Within 4 seconds press button "0" twice.
The present status for days or distance is displayed. Within 10 seconds turn electronic key in steering lock to position 0.
Press and hold button "0", while turning electronic key in steering lock to position 2 again. The present status for days or distance is displayed once more. Continue to hold button "0".
After approx. 10 seconds a signal sounds, and the display shows 10 000 miles (Canada: 15 000 km) for approx. 10 seconds.
Release button "0".
update:
raymond-
47º34'N 122º18'W
raymond- is offline
post #8 of 13 (permalink) Old 08-09-2006, 04:46 PM
Date registered: Aug 2006
Vehicle: 97' E320 Benz
Release button "0".
update:
Hi everyone. I am a new member with a question. I recently purchased a 99' E430. Original owner didn't have an owners manual. I need to know what the L and W button by the gearshift do? what does it mean? Any comments welcome. Thanks
domn8it is offline
post #9 of 13 (permalink) Old 08-09-2006, 04:47 PM
Help....
[QUOTE=domn8it]Hi everyone. I am a new member with a question. I recently purchased a 99' E430. Original owner didn't have an owners manual. I need to know what the L and W button by the gearshift do? what does it mean? Any comments welcome. Thanks
domn8it is offline
post #10 of 13 (permalink) Old 08-09-2006, 08:45 PM
dz111's Avatar
Date registered: Jun 2006
Vehicle: 2006 Clk500, 1954 Lincoln Capri coupe
"w" stands for winter. It starts you off in 2nd gear for traction slippery weather. You want to use "S" for most driving.
dz111 is offline
    HOW DO YOU RESET THE SERVICE LIGHT???? Guest (MBNZ) General Mercedes-Benz 2 06-11-2008 03:06 PM
    E320 CDI service reset Manni.P W211 E-Class 1 12-22-2005 12:00 PM
    how do i reset the service light ? nycxed C208/A208 CLK-Class 6 11-16-2005 08:42 PM
    service light reset JTA00R1 W210 E-Class 1 01-03-2003 01:22 AM
    HOW TO RESET SERVICE LIGHT? Murray C208/A208 CLK-Class 1 05-02-2002 11:55 AM
