» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 07-23-2006, 11:15 PM   #1 (permalink)
Date registered: Apr 2006
Angry Lights flickering?
Anyone know this fix for this problem before I take her to the mechanic? My interior and exterior lights are flickering at idle mostly, my stereo cuts out and turns back on, and When I use my automatic keychain door lock to unlock the car, the dome light blinks on and off (code?)
Any help would be appreciated!
Warren
Warren Lovell is offline   Reply With Quote
Old 07-24-2006, 04:40 AM   #2 (permalink)
no clue's Avatar
Warren
I had similar problem before, the problem come from my OEM CD changer is drawing too much power. ( here is couple thing you can try, if step 1 doesn't works, move to next step)
1. UNPLUG your OEM CD changer from back of your trunk. (not just turn off your radio)
2. UNPLUG your C-slot cable off back of your radio, if you have build in Mobile phone.
3. UNPLUG your "NEGATIVE" cable off your battery for 10 min. (NOT "POSITIVE")
4. Check your Battery power
5. Check your Alternator
p.s. your remote indicator flashing (green red both flashing) means you need to change new battery off your key fob.
Please let us know how it turn out!
no clue is offline   Reply With Quote
Old 07-24-2006, 08:11 AM   #3 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Sounds like your voltage regulator is not keeping the power steady. You could need a new alternator soon. You will have to have your electrical system checked out.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 07-24-2006, 09:17 AM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
check your battery
JOE55 is offline   Reply With Quote
Old 07-24-2006, 02:34 PM   #5 (permalink)
no clue's Avatar
I might rule out the bad voltage regulator.
Defective voltage regulator will cause over charging to the battery more than 12V. (most of Auto voltage regulator limited to 14V current)
First sign of bad voltage regulator is that all the light tends to BRIGHT UP more than usual. (but wouldn't flickering)
Improper grounding or excessive power drawing will cause flickering.
The suggestion of quick CD-Changer removal is similar to the CD-ROM drive in your PC.
When CD-rom drive getting old, the build in resistor failed, the current will continue to draw w/out limit which cause your system to crash, or "un-intentional seeking", even though it seems to read fine.
Old 07-24-2006, 07:49 PM   #6 (permalink)
The radio will shut itself off also and you can hear a snap in the speakers, then it will turn itself back on...I will check the ground cable of the battery and clean the terminals, then proceed. Probably buy a new stereo since the CD changer is now not loading the cds...it just says "loading CD" and nothing happens. The cd cartridge is brand new and did work for about a month.
Old 07-24-2006, 07:59 PM   #7 (permalink)
no clue's Avatar
When you unplug the CD changer, does your car light still flickering?
flickering lights anyone? UPDATE cgeorge430 W163 M-Class 13 02-26-2008 09:34 AM
Flickering Bi-Xenons Pepper W209 CLK Class 6 03-01-2006 12:20 AM
ves monitor flickering jameshsu W163 M-Class 2 06-25-2003 06:28 AM
300 sd - lights flickering Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 01-17-2002 11:09 AM
flickering lights on '88 300e Guest (MBNZ) W124 E,CE,D,TD Class 3 12-24-2001 08:27 PM
