Originally Posted by Ternati2000 I used the diagnostic tool and received the error B1232. This sensor measures the pressure of refrigerant in the a/c system. I was also instructed to override it so the a/c can possibly work. The question is how do I override the sensor?
Thanks and by the way it is 88 degrees outside would love to get this resolved.
Michael |
Sorry for the slow response. I had to break out the climate-control manual for this one, as I can never recall the version codes. BE SURE to write them down before making any changes.
Version Coding:
Programming
1. Turn ignition ON
2. Left side "HI", right side "LO".
3. Turn ignition OFF
4. Press REST and turn ignition ON simultaneously:
"P1" flashes in left side of display window (value 1), right side of display window: (e.g.) "03".
5. Press the right temperature selector (blue = <; red = >).
6. To enter value 1, press EC >1sec.
7. To access value 2, press EC:
"P2" flashes (cycle of 1 Hz) in left side of display window (value 2). Right side of window: (e.g.) "02".
8. Press the right temperature selector (blue = <; red = >).
9. to enter (value 2) press EC >1sec.
10. Turn ignition OFF: A/C (i.e. A/C pushbutton control module [N22]) returns to normal operation.
11. Reset right and left temperature selectors to normal settings.
1. Numerical value
00 - Serial interface K1
08 - Serial interface K1 and K2 (M.Y. 1997)
32 - Auxiliary fan not available as of (M.Y. 1997)
2. Numerical value
00 - engine version over CAN from instrument cluster (as of M.Y. 1997)
08 - Blower motor bar graph switched on by AUTO
16 - Refrigerant fill level check switched off
128 - SMOG display switched off
