Old 06-02-2006, 07:33 PM   #1 (permalink)
DominicArnold's Avatar
Date registered: Apr 2006
Vehicle: 1999 Mercedes E 320
BOSCH PLATINUM+4? Is the dealer OEM
plugs better than the above plug? I was thinking about installing the Iridium plugs, but after reading that they last around 30K miles, changed my mind. Dealer wanted $16.50 per plug, yet can get the above for $6; is there a huge difference?
DominicArnold is offline   Reply With Quote
Old 06-03-2006, 12:43 PM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
+4s are junk. They are sold for people with major oil burning engines. They are not good for a Benz. You can order the same OEM plugs on the internet. Stick with the same model of plug and swap them every 60K miles for the V6. Make sure you get 12 of them. I do mine every 30K in my Inline 6 and only need 6.
Nice to see another AZ owner on here. Be sure and attend our AZ owners get togethers.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 06-04-2006, 06:40 AM   #3 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
Stick with OEM, I put in platinums in my 89 SEC and it ran worse than better.
Peter Guenther is offline   Reply With Quote
Old 06-04-2006, 09:38 AM   #4 (permalink)
no clue's Avatar
I am just curious why bosch +4 are junk?
Yes, I do understand conductivity variation between Platinum and copper.
I also understand the variable also depending on ECU, ignition style, wireset. (hence same plug yield different performance in different type of engine)
I would think bosch, such high tech manufacture will not produce "crappy" plug, no? If within the spec, why one plug be "junk"? And how does anyone or "someone", "my friend", "they said" comes up with this conclusion or data?
I drive? Nothing to brag about, just something depreciate..
no clue is offline   Reply With Quote
