E320 transmission service - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 05-14-2006, 12:17 PM Thread Starter
Date registered: Feb 2006
Send a message via MSN to Chaulito
Hi,
I have a 2000 E320 but I never did the transmission service.
The dealer told me that it sealed and life time warranty so can not be remove.....
is this true ???
THanx
Chaulito is offline
post #2 of 12 (permalink) Old 05-15-2006, 02:12 AM
DETANE's Avatar
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
I Heard The Same Thing... I Dont Know But I Will Ask.
DETANE is offline
post #3 of 12 (permalink) Old 05-15-2006, 11:57 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Chaulito.
Your dealer is fibbing to you. Sealed for life means that when it prematurely dies due to lack of maintenance, it's beyond the warranty period and that's it's life.
Find either a reputable transmission shop that handles premium brands or else take it to your indie.
Search the boards, there are LOTS of threads on this topic. No one recommends leaving it alone. Some suggest intervals as small as 30K, others longer, the average seems to be around 60-70K.
Don't let anyone talk you into just a flush, either, you need to change the filter as well and the quickie-flush places don't do that. Again, search the forums for more info. (The one recently posted by franasia is a good overall primer, more detail in the one started by detane1.)
Take care and enjoy the ride,
Greg
Check Codes is offline
post #4 of 12 (permalink) Old 05-15-2006, 02:42 PM
Originally Posted by gregs210
Hi, Chaulito.
Greg
Im with greg.
I've read a few posts by benz techs talking about the so called 'lifetime oil'. They often report that the oil has a burnt smell. Oil should not smell burnt. My car will get the lifetime oil changed for more lifetime oil in about 15k miles. The lifetime oil is about £200, its not cheap, but its WAY cheaper than a new box $$$$.
my 0.2
wuzoo is offline
post #5 of 12 (permalink) Old 05-15-2006, 02:48 PM
BTW, when my trans blew a gasket and dropped oil over the driveway, my independant could not help. He Could change the gasket, but my ride had to go to MB to get the trans oil level checked. The trans that benz w210's have (typically) need a 'special' mb tool to check that the oil level is correct. Chances are, your local trans specialist, or independant, will not have this vital tool
The point i am trying to make is this. If you get a trans specialist or indy to change your trans oil, then i humbly suggest you take it to benz to get them to check the oil level. If not you could be driving around with too much oil, or to little
MB checked my trans and diff oil and charged me nothing
wuzoo is offline
post #6 of 12 (permalink) Old 05-16-2006, 10:11 AM Thread Starter
Thanx guys..... my car has 80k on it..... i better check it out with a dealer ASAP.
Chaulito is offline
post #7 of 12 (permalink) Old 05-16-2006, 03:00 PM
Quoted: 35 Post(s)
Hey, Chaulito.
Lots of dealers will only give you the "party-line" that it's a sealed unit and won't change it. A good indie should know the procedure both to change it and to check the level, it's not really that complicated. Whereabouts are you located? Some of the forum folks may be able to direct you to a reliable place for the service.
Greg
post #8 of 12 (permalink) Old 05-17-2006, 09:33 AM
Date registered: Jul 2004
Vehicle: 2000 e320 / 2008 BMW X3
Send a message via AIM to johntabako
Greetings,
I requested a transmission oil and filter change at an MB dealer in Huntington, NY and was given the party line. Problem is, i really like this dealer. Anyone know a reputable place in Long Island, NY that would do the service with MB oil and parts?
Thanks,
John
johntabako is offline
post #9 of 12 (permalink) Old 05-18-2006, 06:16 PM Thread Starter
I am in South California, Orange county..... I live in Brea city.....
if anyone know a good place to do the service pls let me know.
Thanx
Chaulito is offline
post #10 of 12 (permalink) Old 04-08-2009, 03:12 PM
Date registered: Apr 2009
CHECKING TRANS FLUID
My mechanic, who is very good, ordered me my own dipstick from MB to check the fluid with. He fixed it so that I do not need a key to check the fluid and I keep the e320 dipstick in my trunk. He flushed my transmission and used the recommended MB trans fluid and the car runs great. Just a thought.
woodstarr is offline
