Can anyone tell me how to get the glovebox out, it seems to be stuck to/glued to the wood trim line. I've pulled the front screws, the two in the floor of the glovebox, and the two door stops. Is there a screw in with the light? I think I loosened one in there, by touch.
Still the glovebox wants to take the whole dash with it, including the airbag part of te dash. HELP!
Thanks!
There is a phillips head screw on each side of the light. I used my wife's handheld makeup mirror to see them and used a short screwdriver to access them. Thanks Honey!
Here are a couple of crappy iPhone photo taken through the mirror.
This looks pretty easy, but I have another question. Our problem is that the fan stays on after we remove the key, thus draining the battery. It does this about half the time ..... They all say we also have to replace the blower in addition to the regulator.
I have the same problem. Were you able to replace just the regulator?
E300D, This has to do with the climate control. I have heat coming out of both side vents, but cold out of the center. I have tried many different settings to no avail. The a/c works out of all the vents when needed. I have not tried getting the test codes yet. I did clean and check the duo valve and it showed no wear or broken parts. Any help would be appreciated
