» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 03-15-2009, 05:46 PM   #21 (permalink)
Date registered: Feb 2009
Vehicle: '93 400E, '97 E420
Originally Posted by Wooly View Post
Lieb-
From what I can tell from the photo at autohaus is that the plug looks the same as all euro's part but the wiring harness is not as long (necessitating the cut & splice of the harness from your original regulator)to make autohaus' part work. all euro's regulator fit just like the original(harness was roughly the same length, although the regulator base plate is shaped differently from the original)no cutting or splicing required/ plug & play. just make sure the plug is aligned to mate with the correct color wires on the car harness...red/red, black/black etc. save $70 by splicing yourself w/ autohaus or peace of mind/ease of install with all euro. hope this helps your decision.
Wooly
Thanks Wooly,
It sounds like a quick fix either way. I need to be in the mood to do the splicing so I'd probably opt for the easier way out. But thanks again for letting me know.
Lieb
liebeskind is offline   Reply With Quote
Old 03-16-2009, 01:42 PM   #22 (permalink)
Date registered: Mar 2009
This looks pretty easy, but I have another question. Our problem is that the fan stays on after we remove the key, thus draining the battery. It does this about half the time, so we have to fix this quickly. We thought we would try the instructions on this site (E320, 2000), but we also called the Mercedes dealer and a couple of Mercedes repair places. They all say we also have to replace the blower in addition to the regulator. What are they talking about! They said it will cost between $800 and $1000. Any help appreciated.
klepin is offline   Reply With Quote
Old 04-10-2009, 09:40 AM   #23 (permalink)
Date registered: Apr 2009
In case anyone is interested, I just found that w140 regulator on Ebay Motors parts and accessories for $88, including shipping. The part number matches the Kaehler regulator from AutoHausz, which now appears to sell for $170. If it works, it saves me nearly a hundred bucks.
Of course I'm cheap...I've been driving an E300TD for ten years!
HoldenBeachBum is offline   Reply With Quote
Old 04-10-2009, 09:43 AM   #24 (permalink)
Oh, and also, that post on MBWorld with all the photos is the best I've found online. That link is somewhere above (hearty thanks to the guy who posted it), and I'll repeat it here. Photo on Ebay matches the part he's got, which gives me confidence.
Old 04-10-2009, 09:44 AM   #25 (permalink)
Whoops...forgot the link. Here it is...
Early W210 Blower Motor Regulator Replacement DIY Here... - MBWorld.org Forums
Old 04-10-2009, 09:51 AM   #26 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
I would recommend avoiding Ebay for any M-B parts. That they list the M-B part number is no indication that the part has any relationship with M-B.
Old 04-10-2009, 01:51 PM   #27 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
I'm with Matt L.
There is nothing wrong with being cheap, but I will never buy a critical part from Ebay. However marketed when the price is "that good" it's invariably a knock-off from China. In the MAF world they fail all the time right out of the box, so I'd not trust the blower regulator either.
I'm not sure that a blower motor regulator is critical, but I also don't like doing things twice. I have yet to have a problem with any part purchased from autohausaz.com, so if/when I face this issue they'll get my business again.
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 04-10-2009, 05:50 PM   #28 (permalink)
Appreciate the advice. We'll see what the part looks like when it gets here! I'll let you all know what I end up with as a part. If it shows up in that blue Kaehler box (good) or if I see any packaging in Chinese (bad) perhaps it will be of interest.
Thanks again for the warning...we shall see...
Old 04-10-2009, 09:01 PM   #29 (permalink)
gregs210's Avatar
Actually the Chinese are very adept at violating copyright law and duplicating packaging, so you can ignore the box.
If only they were that adept at copying the parts IN the box.
Good luck, let us know how it goes.
Old 04-11-2009, 07:19 AM   #30 (permalink)
I consider the blower motor regulator a very critical part. If it is badly constructed, it could cause a fire.
