» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 02-20-2009, 04:22 PM   #11 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
There may be two screws at the top, near the lamp.
Old 02-20-2009, 05:11 PM   #12 (permalink)
w210 lover's Avatar
Date registered: Jan 2009
Vehicle: Mercedes c180 1997 elegance
Send a message via MSN to w210 lover
the glovebox is very tricky . you can force it out with a screwdriver. in the top there is 2 plastic things holding it . you can see what is is here in the last picture
http://www.*****************/Wikka/W210CabinFilter
1997 w202 c180
325.xxx km still going
w210 lover is offline   Reply With Quote
Old 02-20-2009, 06:00 PM   #13 (permalink)
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 4Matic Wagon E320S4 210.282
No need to get glovebox out
Originally Posted by harbrman View Post
Can anyone tell me how to get the glovebox out, it seems to be stuck to/glued to the wood trim line. I've pulled the front screws, the two in the floor of the glovebox, and the two door stops. Is there a screw in with the light? I think I loosened one in there, by touch.
Still the glovebox wants to take the whole dash with it, including the airbag part of te dash. HELP!
Thanks!
If you're doing just the blower regulator, the access is directly from the footwell area removing the two screws. I mentioned removal of glovebox on tutorial because I did the air filters at the same time.
To remove the glovebox I grab it from its door, close to the hinge. The I pull upwards, like an arch, if you look from the side.
Hope it helps.
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is online now   Reply With Quote
Old 02-21-2009, 09:38 AM   #14 (permalink)
247hoopsfan's Avatar
Vehicle: 98 E320 88 300E
You don't need to take out the glove box. The blower motor and regulator are accessible from beneath the glovebox. Just loosen the screws down there and you have full access.
1984 300D 225,000 miles (hit and totaled by bad driver)
1987 300E 209,000 miles (donated to worthy cause, still going)
1988 300E 205,000 miles (still a daily driver)
1998 E320 70,000 miles (Obsidian, 17' E500 rims)
1990 300CE 88,000 miles (Silver/ black int)
247hoopsfan is offline   Reply With Quote
Old 03-05-2009, 07:35 PM   #15 (permalink)
Vehicle: 1998 E320 wagon 173k
I have a '98e320 wagon w/ the old style regulator(not like the new one pictured at the beginning of this thread). I purchased the part from all european auto supply for $236+shipping. Their part # is 2108219951. It is KAE brand (3.701.420 is on the box). Looks exactly like roring's part from his repair(the last picture) on the MB world.org website with the plug from the original harness. Got it today and installed it in about 20 minutes(had removed blower earlier in the week) Doesn't get much easier than this and no soldering/splicing required. Blows like a champ.
http://www.mbworld.org/forums/e-clas...-diy-here.html
Last edited by Wooly : 03-07-2009 at 02:01 AM. Reason: quoted wrong name(roring NOT tony)
Wooly is offline   Reply With Quote
Old 03-05-2009, 07:46 PM   #16 (permalink)
Originally Posted by Wooly View Post
I have a '98e320 wagon w/ the old style regulator(not like the new one pictured at the beginning of this thread). I purchased the part from all european auto supply for $236+shipping. Their part # is 2108219951. It is KAE brand (3.701.420 is on the box). Looks exactly like Tony's part from his repair on the MB world.org website but with the plug from the original harness. Got it today and installed it in about 20 minutes(had removed blower earlier in the week) Doesn't get much easier than this and no soldering/splicing required. Blows like a champ.
That's interesting. Where was it made? I've never heard of the brand.
Old 03-05-2009, 08:39 PM   #17 (permalink)
Kaehler Automotive Equipment K.A.E Made in Germany.
Can also purchase same regulator at autohausaz but in their photo it does not appear to be as long the original harness. Their part # is 1408218351.
http://www.autohausaz.com/search/pro...ber=1408218351
Old 03-07-2009, 01:59 AM   #18 (permalink)
Take a look at this thread @ MBworld.org. It has photos.
Early W210 Blower Motor Regulator Replacement DIY Here... - MBWorld.org Forums
Old 03-14-2009, 08:56 PM   #19 (permalink)
Date registered: Feb 2009
Vehicle: '93 400E, '97 E420
Question
Wooly, are you saying that the part from Euro Auto Supply just plugs in without any splicing? And the one from Autohaus doesn't? Please let me know...I'd rather not splice when the time comes for my a/c to quit.
liebeskind is offline   Reply With Quote
Old 03-15-2009, 03:23 PM   #20 (permalink)
Lieb-
From what I can tell from the photo at autohaus is that the plug looks the same as all euro's part but the wiring harness is not as long (necessitating the cut & splice of the harness from your original regulator)to make autohaus' part work. all euro's regulator fit just like the original(harness was roughly the same length, although the regulator base plate is shaped differently from the original)no cutting or splicing required/ plug & play. just make sure the plug is aligned to mate with the correct color wires on the car harness...red/red, black/black etc. save $70 by splicing yourself w/ autohaus or peace of mind/ease of install with all euro. hope this helps your decision.
Wooly
