Engine oil and Transmission fluid clearification
2K views 3 replies 4 participants last post by  vodica
There are a lot of posts about these...Im just looking for some clear precise info on this. I have a 98 E320, it does have the locking plug on dipstick tube...I believe I have the "non Service" tranny (722.?)< Am I correct? Should I use ONLY MB tranny fluid? What else can I use and what documentation backs it up? Where is best place to but dipstick tool?
The same for Engine oil. I have been told to ONLY use MB approved synthetic with the MB approval # on the back. Well, the "full synth Mobil" says it is approved for MB BUT it does NOT have the "approved" MB Ref.# on the back...What does all of this mean?? I do not mind paying for the MB tranny fluid, but I put a lot of miles on the car and would love to find a SAFE replacement for the MB engine oil.
Any info,documentation,web links etc.would be great!!
Thanks,
S.
Use ONLY the MB trans fluid..and YES service the (SEALED) trans @60K..make sure that you drain the torqueconverter...I have seen first hand what happens when you use a Normal ATF in a late 722 trans...NOT a Pretty site!
Read the owners manual re other oils that one can use..I would recommend Mobil One
Oil Changes are Cheap Insurance!
Purchase the trans dip stick at a MB dealer...and replace the tamper proof plug at the dipstick...
#3 ·
Don't think the manual lists the approved oils since it is a changing list.
See the current list here or get one of these http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8040569932&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1
Len
#4 ·
MB sheet 229.3 approved oils
for passenger cars with gas and diesel engines with extended drain interval indicator FSS up to 20,000 km, or 40,000 km - 25,000 mi, current minimum spec for 1998+ MB engines, min. 1.0% fuel saving compared to 229.1, based on ACEA A3 B4. For gas engine of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
AGIP EXTRA HTS 5W-40
AGIP Synthetic PC 0W-40
AGIP Eurosport 0W-40
Amsoil 5W-30 Synthetic Motor Oil
Amsoil 10W-30 Synthetic
Amsoil Series 3000 5W-30 Heavy Duty Diesel
Aral HighTronic 5W-40
Aral SuperSynth 0W-40
Aral Super Tronic 0W-40
Aviasynth 0W-40
Castrol DCO TOPUP SAE 0W-30
Castrol Formula RS Road and Track 5W-40
Castrol GTX7 DYNATEC 5W-40
Castrol Formula SLX 0W-30
Castrol TXT SOFTEC PLUS 5W-30
CIFAB Synthoil Hydrocrack HC7 5W-40
Elf Excellium LDX SAE 5W-40
Esso Ultron 0W-30 (fuel economy)
Esso Ultron 5W-40
Fuchs Silkolene Pro S 5W-40 - 100% Synthetic Oil For All Race Engines
Fuchs Silkolene Pro S 10W-50 - 100% Synthetic Oil For All Race Engines
Fuchs Titan SuperSyn SL 0W-30
Havoline Synthetic DS 0W-30
Kendall GT-1 Full Synthetic 5W-40
Liqui Moly Diesel Synthoil 5W-40
Liqui Moly High Tech 5W-40
Liqui Moly HC7 5W-40
LUKOIL SYNTEETIK 5W-40
Mobil 1 SuperSyn European Car Formula 0W-40
Mobil 1 SuperSyn 5W-40
Mobil 1 SuperSyn 5W-50
Mobil 1 Turbo Diesel 0W-40
Mobil Synt S 5W-40
Mobil Synt S Turbo Diesel 5W-40
Mobil Syst S 5W-40
Motul 8100 E-Tech 0W-40
Motul 8100 X-cess 5W-40
Pennzoil Synthetic European Formulation 5W-40
Pentosin Pentospeed 0W-30 VS
Quaker State Full Synthetic European Formulation 5W-40
Schaeffer Micron Moly 5W-30, 10W-40
Schaeffer Supreme 7000 5W-30, 10W-30, 20W-50
76 Pure Synthetic Motor Oil 5W-40
Shell Helix Plus S 5W-40 (Mercedes-Benz)
Shell Helix Ultra 5W-30, 0W-40, 5W-40
Sunoco Synturo Gold 5W-40 (introduced January 2002)
Total FINA First 5W-40
Total Quartz 9000 5W-40
Valvoline DuraBlend MXL 5W-40
Valvoline SynPower MXL 0W-30
Valvoline SynPower 5W-30, 0W-40, 5W-40
Veedol POWERTRON 5W-30
Veedol SYNTRON 0W-30
