I am ready to purchase an extended warranty on my 02 4Matic and AAA is the only one that comes to mind. Any other suggestions? I have looked into the archives and there is not much help there.
RE: Extended Warranty: How is AAA extended warranty?
Thanks for the info. Now they have several different types of coverages. My car is an 2002 4matic and has only 17800 miles on it. What kind of coverage should I choose? Bumper to Bumper or something like:
https://www.carwarranty.com/whats_covered.asp
which is nothing more than this:
Engine -
(a) The following lubricated internal parts: pistons, pins & rings, connecting rods & bearings; crankshaft & main bearings; camshaft, followers & cam bearings; push rods, valves, springs, replaceable guides, seats & lifters; rocker arms, shafts & bushings; timing gear, chain, tensioners & retainers; eccentric shaft; oil pump.
(b) Timing belt; serpentine belt; Water pump: Impeller shaft, bearings, bushings & housing; intake & exhaust manifolds; engine mounts & cushions; engine torque strut; harmonic balancer; flywheel (flexplate) & flywheel ring gear; mechanical fuel pump; dipstick & tube; all pulleys.
(c) All lubricated internal parts of the vehicle manufacturer installed turbocharger or supercharger.
(d) Engine head(s); engine block; cylinder barrels; timing cover; valve cover(s); oil pan; dipstick & tube.
Transmission -
(a) All lubricated internal parts contained within the case(s).
(b) Computer modules & solenoids; filler tube & dipstick; vacuum modulator; internal linkage.
(c) Transmission case, transfer case & torque converter case.
Drive Axle -
(a) All lubricated internal parts contained within the housing(s).
(b) Axle shafts; constant velocity joints (CV); universal joints; drive shafts; locking hubs; locking rings; supports, retainer & bearings.
(c) Differential housing, transaxle housing & final drive housing.
Bumper to bumper, there are a lot of electronics in engine control, and 4matic. I dont like non manufacturer warranties, you could end up in the middle if the dealer thinks one way and the insurance another.
