Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Originally Posted by acarter53
I don't know . I feel that if I use the fleece filter, it should protect the engine from anything that I can not pump out. The dealers does it this way all day long with cars the are worth much more than mine. I do not think that they would risk buying a new engine for a S 55 or CLS 65 if this was not a good method for changing oil. But at the end of the day its all about what you feel is best for your car. My $0.02 worth.
I use to change the oil in my BMW 740il by removing the drain plug and that was a pain in the ass. That car was big and heavy and low to the ground. I had to remove 3 shield to get to the drain plug. I'm not going back to that again.
thank you, im still learning so your opinion was greatly welcomed. Main reason is I wanted to change the oil myself verses paying them. I will check around for the cost.
I will do the B service. I may take it in for the A just to get a list of items that I need to do. then I go home and take care of all of the items that are on the list.
Originally Posted by slybydesignw210
oh ok, cool thanks for the info just one last q - what do they do for service A? they want to charge me $340 for B and they never quoted me for A
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
